Help With Random Misfire codes
Old 04-23-2015
rcolosi's Avatar
rcolosi is an unknown quantity at this point
Figured I'd just run this by you guys and see if there are more things to consider: (2000 Civic DX)
- CEL Codes for random misfire cyl 1 & 2
- Car is fine, but ONLY stumbles under load/acceleration and only at cruising speeds. Idles perfect, starts perfect
* replaced:
- distributor/Ign module/coil
- Wires & plugs
- Fuel pump & filter
- swapper injectors 1/2 to 3/4...same codes for cyl 1 & 2 persist
- Timing belt was swapped a while ago for routine maintenence
any other obvious things?
Thanks!
Old 04-28-2015
davidpaustin's Avatar
davidpaustin is an unknown quantity at this point
Re: Help With Random Misfire codes
One thought would be to check your IACV. I know it sounds odd, considering your idle is fine, but I had an issue with how my car was driving and after I pulled the IACV I cam to the realization that the guy I bought the car from, was probably running water instead of coolant. There was a large piece of rust flapping back and forth inside the IACV causing major issues, particularly when in low rpms.
Old 04-28-2015
rcolosi's Avatar
Thanks!!
Old 04-29-2015
01hxcivic's Avatar
01hxcivic is an unknown quantity at this point
Had a similar problem with 01 civic, cleaned injectors problem went away.
Old 04-29-2015
rcolosi's Avatar
Just got it back.. my guy found the fuel pressure regulator vacuum hose kinked badly and the valves were all very tight .001" -.002" Runs perfectly now. Not what i expected, but it works!
Civic15
18
09-19-2017 07:48 PM
Dani1993
07-24-2015 09:02 AM
jzhartman
22
07-23-2015 10:42 PM
mistermenphis22
07-13-2015 04:43 PM
Youshoe
Air Conditioning
07-08-2015 09:49 AM
Quick Reply: Help With Random Misfire codes
