Rotor Issues?
Old 04-11-2015
tattedlariat's Avatar
tattedlariat is an unknown quantity at this point
Rotor Issues?
I replaced the rotors and brakes on my 2000 civic today. I just bought the car yesterday.
And now its got this god awful squealing coming from the front drivers side wheel, but i couldnt see where anything hit.
Any ideas?
Old 04-11-2015
Prelude Owner
GolNat's Avatar
Re: Rotor Issues?
Did you re grease the slide pins and put grease on the back of the pad shims where they touch the caliper?
Old 04-11-2015
Re: Rotor Issues?
Nope. I'm assuming thats probably my problem!
Old 04-11-2015
Prelude Owner
GolNat's Avatar
Re: Rotor Issues?
Probably, I would start with that first. Use a liberal amount on the back shims. I like to remove all the old grease from the slide pins before adding new grease. Use a liberal amount on these also.
Hopefully none of your slide pins are seized.
Old 04-12-2015
Re: Rotor Issues?
Put grease on it, made it better, but still had a noise. Turns out, i had the brake pads all the way up on the rotor. Whoops!
Old 04-12-2015
Prelude Owner
GolNat's Avatar
Re: Rotor Issues?
glad you figured it out. It was good to grease those parts anyway. Now you are good to go.
Misfit2613
Brakes
26
09-01-2018 05:02 PM
masongap
05-26-2015 07:55 PM
dpru
05-26-2015 07:01 PM
Grey
17
02-21-2004 06:21 PM
Quick Reply: Rotor Issues?
