Problem with manual door lock/key 2008 Civic
Rep Power: 0 Problem with manual door lock/key 2008 Civic
I have a 2008 Civic DX, 4-door, with a manual key entry system. Lately the key is very difficult to get into the slot on the driver's door, and if it does happen to go in it may not turn at all. On all other locks, the keys work fine. I've tried graphite, oil, and WD40 to loosen it up, but no luck.
The dealer tells me this happens often (!?), and that they can fix this for about $275 by putting in a new lock.
Does anybody have any advice - is there a repair the owner can try on their own? Related to this, how does one get the inside door panel off?
Thanks.
Thanks.
Re: Problem with manual door lock/key 2008 Civic
If at all possible (it's not always possible), instead of replacing a cylinder with new keys, I think it's preferable to rebuild the original cylinder with new tumblers so you can still use the original keys. If replacement is needed, the new lock should still be retumbled to you can use the original keys IMO. Kinda hard to know what it's gonna need until it's taken apart and evaluated. Can't do that over the phone.
The price is the price. Sometimes locks can be a real PITA and well worth paying someone to not break a bunch of stuff getting it apart.
To save on labor cost: Extract your bad lock cylinder yourself, carry it in to the dealer and have them rebuild it ?
Take it apart and remove just the offending tumbler(s)?
Ask local locksmith shops? (In my town, the dealer is the only one that can do these locks and keys.)
CarStuff
12-06-2020 12:52 PM
