Lost power on freeway, cranks but nothing else
Rep Power: 0 Lost power on freeway, cranks but nothing else
Hi all, I have a 99 Civic EX that died on the freeway coming home from work. I can't remember if I lost electrical at that time, but engine power for sure.
I can currently turn the electrical system on, no OBD codes, and when I turn the key it sounds like its cranking something steadily and with plenty power, but nothing else happens.
So far I have charged the battery, and changed out the distributor. The car sounds the exact same as it did the day the problem occurred. I wasn't sure I had the original distributor orientation correct so I switched it back and forth once or twice, still the same cranking sound.
I'm by no means a mechanic, but if I had to make a guess I'd say fuel pump or spark plug, but maybe not spark plug because I think the engine would start just a little if that were the case.
Thanks a ton guys, I need to get back to work!
Re: Lost power on freeway, cranks but nothing else
it sounds like your timing belt has snapped,
does it sound like its cranking alot faster then it normally does?
yes = timing belt
remove your oil filler cap, have somebody crank the engine while you look into the oil filler cap with a flashlight, while the engine is cranking you should see movement in there and some oil splashing around,
if you see no movement at all = timing belt
yes = timing belt
Whachya lookin at?
Rep Power: 288 Re: Lost power on freeway, cranks but nothing else
Don't crank it any more.. you need to remove the valve cover and timing belt cover and see if the timing belt is intact. I'd personally check for spark and fuel first but these cars are notorious for dying due to snapped belt (and running through absolutely everything else). Any check engine lights?
Rep Power: 0 Re: Lost power on freeway, cranks but nothing else
The engine sounds like it's struggling to try hard with no luck, a higher pitched wailing sound (2-tone high-low).
Honestly I can't tell the difference in speed of the cranking compared from before to now, it sounds about the same except it just won't start.
I can't check the flashlight in the oil cap (while starting) for now since my wife won't be home from work for a few more hours.
The only lights on are oil and battery, though like I said before the battery seems pretty strong judging by the strength of the crank.
I think I'll check out under the valve cover for now, though the last time I worked on a Civic myself was around 2002 in high school on my b16 type-r.
Thanks guys, I really appreciate it. I'll post another update soon enough.
I got the valve cover off, I can't remember if the timing belt is supposed to be tight or not, when I poke the belt it seems a little loose. Now I need to figure out how to access the belt.
Just wait til the spouse gets home, have her crank it for you.
Or get one of the neighbors, offer a beer for their time LOL
Or maybe mark the cam pulley with a sharpie, then crank it, then see if the mark moved. If it didn't move, it's toast.
Alright so I cranked it while looking with a flashlight into the oil cap, no movement. I also marked the sprocket, belt, and reference point on the cover and it didn't move a bit. I guess it was the timing belt after all. Thanks guys!
Bent valves? Plan accordingly.
You already have the valve cover off.....Look for any rockers that have a whole lot of clearance.
Every quarter turn of the cam gear is a different cylinder.
jbradley4809
04-07-2017 04:23 AM
Supramk3
05-08-2015 11:16 AM
