1999 Civic Coupe Power Door Lock
Old 10-29-2013
Burleyman14's Avatar
Burleyman14 is an unknown quantity at this point
Good Morning.
I just replaced the driver side door actuator last month and it worked great until today. Now, I cannot lock the door with the key or manually using the lock tab. The actuator does not even click or make any sort of noise when I hit the key fob. Seems like an electrical problem, but I'm not sure where to start. Also, it seems strange that I cannot manually lock the door with the key or interior lock tab... BTW, the passenger side door lock works fine using all methods to lock...
Thanks
Old 10-29-2013
Re: 1999 Civic Coupe Power Door Lock
This makes it an apparent mechanical issue. Do these work when the door is closed?
Does the door close all the way, or is the latch only in the half-shut position?
Old 10-29-2013
Open or closed, it doesn't matter, I cannot lock the door. Door closes fine and the latch is in the full open position. The actuator is not even attempting to lock or unlock the door, it's not making any sound what so ever...
Old 10-29-2013
Well, everything probably originates at the latch. If you can't manually get it to lock/unlock, the actuator probably can't make it work either.
The latch must be fully closed (both detents) OR either inner or outer handle be pulled in order for the lock mechanism to move.
If it doesn't work by either method, I'd probably be pulling the latch out of the door and pulling the actuator off of it to see what is going on.
HTH
Old 10-29-2013
I guess I should mention those cars can have wiring issues that typically involve broken wiring in the door jamb/door connector........
But your problem sounds primarily mechanical not electrical IMO.
Old 10-30-2013
Thanks for the info. I was hoping to avoid pulling everything apart again, but that's where I'll start. Thanks again...
roverben
01-21-2019 05:16 PM
usajags84
05-10-2015 08:11 AM
darwin-t
04-18-2015 09:29 PM
Killagi
04-12-2015 10:42 AM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
11-07-2001 11:19 PM
Quick Reply: 1999 Civic Coupe Power Door Lock
