Alternator/SP Sensor fuse blows (7.5A)
Old 10-16-2013
Akd1991
Akd1991's Avatar
Akd1991 is an unknown quantity at this point
Hello everyone, I am driving a 98 Honda civic 3Dr. To start with the alternator is rather new and the o2 sensors have just been replaced. The speedometer does not work and it has been proven that it is a bad instrument cluster. When there is load on the engine the alternator/SP Sensor fuse blows out and the car begins to die. When the fuse blows we get multiple codes: p1298 (elc circuit high input), p0135, P0141 (02 sensor heater circuit banks 1 and 2). When we first got the car we replaced this fuse and it didn't blow for a few months. Now it blows whenever you start driving it.
Any ideas people?
Can I use a 10A fuse instead of 7.5A?
How to trial test this type of problem?
Old 10-16-2013
Akd1991
Akd1991's Avatar
Re: Alternator/SP Sensor fuse blows (7.5A)
Now it blows as soon as you start the car.
Old 10-16-2013
Your answer is probably this
http://www.tegger.com/hondafaq/misc/...%2315_fuse.pdf
Old 10-18-2013
Akd1991
Akd1991's Avatar
Ok, before I check the harness. I unplugged the alternator and now the fuse doesn't blow. In everyone's opinion is the underlying cause a short in the alternator or a short In the wires connecting the alternator to the car? Should I replace the alternator to rule the wires out?
Old 10-18-2013
Could be the alternator, sure (but IMO that's pretty rare)....But when you disconnected it you also could have jostled the wire harness just enough to temporarily stop the short to ground where the harness rubs through on the bracket (as described in the bulletin).
How about leave the alt disconnected,
use a good fuse,
then wiggle the wiring harness all through the area the bulletin talks about,
see if the fuse blows.
If it blows, then its the wiring problem.
If not, then plug in the alt and see if it blows.
Old 10-20-2013
Akd1991
Akd1991's Avatar
You Sir where right on the money. The diagram helped a lot. I found a bare wire and am currently in the process of repairing it. Thank you!
Old 10-20-2013
YW.
Thanks for the feedback.
Old 07-20-2017
David Rodriguez's Avatar
David Rodriguez is an unknown quantity at this point
Originally Posted by ezone
Hey I'm new here, I am having the same issue but when I go to the link it says it does not work is there anyway I can get a working link.
Old 07-20-2017
I wonder of all of the info on that site has been taken down......
Try this link
http://www.justanswer.com/uploads/lorunner/2008-10-31_214611_96_civic_fuse_blows.pdf
Harding12390
04-06-2018 11:43 AM
JAMorganIII
23
07-04-2015 11:52 AM
g4384063
05-30-2015 11:21 AM
Ma213802
05-18-2015 07:01 AM
Gunner
Engine DIY
10-06-2012 12:37 PM
Quick Reply: Alternator/SP Sensor fuse blows (7.5A)
