Leaking P/S Fluid :russian:
Rep Power: 0 Leaking P/S Fluid :russian:
Hello everyone. First off id like to say that im new to this forum.
my issue is that im leaking alot of what appears to be power steering fluid.
now ive traced the line and its the one from the reservoir going to the rack (low press hose?). is it hard to replace? anyone know the steps or have pictures? thanks.
98 civic d16y7 auto
98 civic d16y7 auto
Re: Leaking P/S Fluid :russian:
A 10mm socket or wrench should fit the clamps if they are original. You would need to figure out how to reach them on your own.
Clamps you can tighten are labeled (a)
Close up view at the steering rack
It IS just low pressure hose on the return side, I have used bulk hose (that is compatible with petroleum oils) from a parts store to fix rusted out lines on one of my own old cars. It took about 10 feet to wrap around the front of my old Buick.
Rep Power: 0 Re: Leaking P/S Fluid :russian:
shall i just spray some pentrating fluid on the clamps?
If they are too far gone, just replace them.
Where can i get the line inbetween the 2 clamps?
http://torontohondaparts.com/OrderParts.aspx
Pick out your car, then Chassis, then P.S. Lines
HTH
Hello again. the part came in today from british columbia. ive successfully installed the new line and new clamps. the leak has stop. thanks for your help =)
Causemo
07-05-2015 06:42 AM
Causemo
07-04-2015 07:11 AM
SuperEF
06-24-2015 11:53 PM
