Help my oil is disappearing
Rep Power: 0 Help my oil is disappearing
I have a 1999 honda civic si with a d16y8. I have to fill it up every 2 days and there is very little oil around the engine bay. Any input would be appreciated I have redone the oil pan gasket and the valve cover gasket as well
A true genius admits that he/she knows nothing.....CLOSED SAT/SUN
Rep Power: 164 Re: Help my oil is disappearing
Does the car smoke when you drive it? or at start up? see if you have smoke coming out the back.
10 miles? 800?
Rep Power: 0 Re: Help my oil is disappearing
It doesn't smoke and I usually drive about 200 to 300 Km. i checked under the car and there was oil by the crank shaft seal but there is a slight burnt smell like oil cooking
That car you have isn't a si. D16y8 is from a EX model.
Just stating the fact.
Received 1,148 Likes
Rep Power: 485 Re: Help my oil is disappearing
Canadian Si = USDM ex
Canadian SiR = USDM Si
That's how.
OP's post above yours states "kms," alluding to the fact that OP resides in Canada.
That's how.
Whachya lookin at?
Rep Power: 289 Re: Help my oil is disappearing
It's a popular swap. It's been swapped in for sure. Does it say "SiR" on the cluster? If it doesn't say SIR someone swapped in the B16.
Whachya lookin at?
Your contradicting yourself in that post. If it IS a Canadian Si then it HAS been swapped with the B16. If it is an AMERICAN Si it has NOT been swapped and it is an OEM b16.
So, your saying it's a Canadian Si, someone has swapped the engine.
Sorry I wasn't clear. in Canada the civic si has a d16y8 known as a civic ex in the states the civic Sir in Canada has the b16 and is known in the states as the civic si unless Wikipedia and other sites are wrong
To the OP, check for smoke coming out the tail pipe. It might go undetected if you're checking by looking through your rear view mirrors. Have a friend start up your car while you stand behind it.
I had a similar problem with a Mazda Protege5. I switched my head gasket (not to be confused with valve gasket) and that was a temporary fix. I started burning through oil again later on and I ended up junking the car. I think your block might be ever so slightly warped.
Did you ever overheat the engine?
No prob. And I haven't overheated the car. I'm not sure about the owner who had the car before me. I'm in the middle of replacing the crank shaft oil seal which was surrounded by oil and the base of the dip stick tube
emich
12-11-2015 12:20 PM
fafa1234
08-08-2015 06:42 PM
fecrni
08-08-2015 06:15 PM
muttleytm
07-11-2015 06:00 PM
