d16y7 leak problem
d16y7 leak problem
okay, I have a coolant leak.
I know its a coolant leak because I flushed and filled my radiator with coolant/antifreeze
and it was leaking. just to make sure, I flushed and filled it again and this time with water.
People say its my head gasket. But I don't think it is because
if it was my head gasket, my exhaust would be throwing up white smoke.
and its not.
So im guessing its my water pump or so.
if it is, can someone tell me how to change it like DIY thing?
cause I don't want to pay for labor just to get it fixed.
and its not.
Re: d16y7 leak problem
Time to get some beers and have all my buddies stand around and make guesses at what is leaking.
And these guys came up with........
and its not.
and its not.
(If it has been overheated, it probably does need a head gasket job, along with having the head checked and milled flat again, if possible. PLUS you still have to figure out and fix the original problem that caused that.......or else you will be doomed to repeat it.)
Your search-fu is weak.
I guess that if you can't follow a simple water leak from the ground to the source to figure out......................
I'm gonna look into the future for a minute
I don't see this ending well any time soon.
EDIT: Damn, that was bad. I need some coffee...
ishjay, go to the store and buy either a Haynes or a Chilton's manual. You will be amazed at how detailed it is. It will definitely help you change the water pump. And yes, it can be done with the engine still in the car.
How do I line up everything?
Do I need to line up water pump too?
I got one but don't bother to open it.
Anyway, I finally opened the book and read about the water pump. Looks pretty easy. Lol
But damn, the part from the bottom something about the oil seal. I need to remove some oil seal. That's kinda easy but the crank removal. Its hard. And there's some stuff that I don't understand
It's easy if you have the right tools for the job.
WaryDriver
05-27-2015 05:54 AM
crowtoo
05-11-2015 06:50 PM
Ninetyatecivic
05-09-2015 07:48 PM
