Need some help Regarding P1163 error code!!
Eight months ago, when i first bought this car(1999 honda civic HX), I had to replace oxygen sensor(upstream) on this car. I bought the OEM NTK wideband O2 sensor. A month ago the check engine light came on. So I scanned the code and found out that the error code read P1163, which is HO2S11 Slow Response. Since i bought the car i have only put ~11,000 miles on it and from what I have heard is that O2 sensors usually lasts till 50,000 miles. But anyways i reset the code and it was fine for like a month(drove for 1100 miles) and yesterday it came back on again. The guy at autozone told me to replace the downstream sensor as well because that might trigger error code as well.
So my question is that do I have a faulty upstream O2 sensor or do I really have to replace my downstream sensor as well? Or what else could be the problem
I read it in the forum below that putting after market wheel could trigger a false alarm.
http://honda-tech.com/showthread.php?t=2242027
Ps. The car does have exhaust manifold leak, has been lowered and has 17" rims (dont know if that adds up to the prob )
Thanks for any help
Thanks for any help
Re: Need some help Regarding P1163 error code!!
If the exhaust manifold leaks, I would certainly fix that first.
That is an obvious problem that can affect O2 readings.
It can let fresh air get in and skew the sensor readings, bias them lean.
Braze or weld the crack, or replace the entire thing?
If that doesn't fix it, then do a search for Honda bulletin 00-028.
Only for HX Civics 1998-2000, "ECM is too sensitive to driver input", a modified/updated/countermeasure PCM was the fix.
A standard original replacement ECM or a reman of an original will not fix it.
PM me if you need more info about this bulletin.
I'm not sure I believe the wheel theory.....but I know they can affect odd things. More rolling resistance = more load on the engine.
I don't believe the rear sensor theory at all.
I would ignore almost everything that the Zoo employees tell you. If the people there could actually fix cars, they wouldn't be parts ******. (Same goes for most tow truck drivers.) They probably get a commission from all the parts they sell, so that is the motivation for selling you the fully loaded parts cannon, loaded with the cheapest parts they can source from China. They don't give a flying rats azz about actually fixing your car.
I have seen an exhaust leak cause this code on Hyundai's, not on a Honda.
But you probably want to get that taken care of first ^^^^
this is from Honda, if not an exhaust leak causing it. this is most likely your problem.
TSB 00-028
Applies To:
TPS - between 3% and 7%
TSB 00-028
Applies To:
1998-00 Civic HX M/T - ALL
MIL Comes On With DTC P1163
SYMPTOM
The MIL is on with DTC P1163 (O
2 sensor slow
response) stored in the ECM, and the customer does
not have any driveability complaints.
PROBABLE CAUSE
The ECM is too sensitive to driver input.
CORRECTIVE ACTION
CORRECTIVE ACTION
Review the DTC Freeze Data, and if the Freeze Data
values are within the ranges listed in DIAGNOSIS,
replace the ECM.
replace the ECM.
DIAGNOSIS
1. Use the PGM Tester to retrieve the Freeze Data.
2. Review this Freeze data: RPM, VSS, ECT, and
TPS.
Are the Freeze Data values within the ranges
specified below?
specified below?
RPM - between 2000 and 2800
VSS - between 35 and 55 mph
ECT - above 160F
ECT - above 160F
Yes -
Current ECM P/N Replacement ECM P/N
37820-P2N-L31 37820-P2N-405
H/C 6444905
37820-P2N-A31 37820-P2N-406
H/C 6444913
37820-P2N-L32 37820-P2N-L33
H/C 6432579
37820-P2N-A32 37820-P2N-A33
H/C 6444913
H/C 6432579
H/C 6432561
Go to step 3.
No -
Disregard this Service Bulletin, and follow
normal troubleshooting procedures.
3. Remove the right kick panel.
4. Find the part number on the current ECM, and write
it down.
5. Locate the part number of the current ECM under
PARTS INFORMATION, then order the appropriate
replacement ECM.
replacement ECM.
Civic15
18
09-19-2017 07:48 PM
mjdiaz89
06-21-2016 09:26 PM
jessica19699
07-29-2015 05:51 AM
Green02civic
07-27-2015 10:48 PM
cgavin1
07-07-2015 07:10 AM
