Adjusting valves After Removing Camshaft Help..
Rep Power: 0 Adjusting valves After Removing Camshaft Help..
Ok, so I really don't know what happened to my mind, lol not sure if after my car accident I lost my memory, lol I dont think so but i completely am at lost with this process hopefully someone could help me, Ok so this is what Ive done.
I removed my cylinder head to replace my headgasket, so I removed my rocker-arm assembly, loosened the valve spring tension that it had on the valves and also removed the camshaft in order to get my head resurfaced and checked for leaks,
so here is my question, I put the head on my engine already and its where i got a brain fart, after I put every on tdc and put my timing belt back on how to i go about adjusting my valves back to spec, right now all the valve lash are completly loose, so since my engine will be on tdc do i adjust my valves on the #1 cylinder the rotate the crankshaft 180 degrees and adjust all the valves on cylinder #3 then rotate the crankshaft another 180 degrees and adjust all the valves on cylinder #4 etc etc so does this procedure sound right?
oh its a 96 civic ex
Re: Adjusting valves After Removing Camshaft Help..
Your procedure sounds reasonably close. Get a shop manual and make sure.
I don't necessarily need to know the firing order when I do them (I do all kinds, not just 4 cylinder engines), I watch the valve action as I turn the crank and do whatever cylinder is on TDC with all the valves closed. Its companion cylinder must be on valve overlap at the same time.
Received 1,440 Likes
Rep Power: 338 Re: Adjusting valves After Removing Camshaft Help..
7thgensurvivor
38
08-29-2015 11:50 AM
WKD DRGN
06-18-2015 07:56 AM
FurBall
06-10-2015 03:13 PM
Supramk3
05-11-2015 07:55 PM
