Steel Brake Lines, Softer Pedal? WTF
DIY Enthusiast
Rep Power: 0 Steel Brake Lines, Softer Pedal? WTF
I have a 98 Civic EX with the SI rear disc brakes. I've never had trouble with these brakes the entire 9 months I've owned the car.
Today I put braided steel brake lines on the rear ONLY. I did them one at a time and made sure that they had the appropriate washers and were bled thoroughly. The bolts are tight on the caliper and there are no visible leaks.
Now the problem is my pedal is softer than when I had the stock rubber lines on.
Please help if you know what could be the problem!
DIY Enthusiast
Rep Power: 0 Re: Steel Brake Lines, Softer Pedal? WTF
Yes, I put up there that I bled them thoroughly while making sure the reservoir was kept filled. The brakes still grab well and it isn't intermittent at all.
Odds are you didnt bleed them enough...heres a guy that had the same experience
http://forums.bimmerforums.com/forum....php?t=1324280
DIY Enthusiast
Nope, no ABS thankfully. It does seem like I'll need to bleed more the more I read. It has to be it. I'll give it a shot and post up the results
Please, DubTee is my father, call me Dub
No ABS, start with the wheel furthest from the master cylinder and work from longest line to shortest line. Mity Vac will pay for itself if you aren't already using one
WaryDriver
23
07-22-2015 07:18 PM
Keenan Keenan
07-01-2015 10:58 AM
02EXCoupeGuy
12-19-2001 09:47 PM
