Oil Change?????
Rep Power: 0 Oil Change?????
I have a 99 Civic LX and will be changing the oil for the first time. What is the best tool to remove & tighten the oil drain plug? Do I really need a torque wrench? What oil filter should I use? I was thinking of a Purolater Classic.
Thanks
Thanks
Re: Oil Change?????
You're seriously gonna ask that?? Usually mechanic gloves will get that bolt out lolz .
Forum rule #1: search before you ask
Did you search for the answers? Read the DIY for changing oil.
Mobil 1, amsoil, pure 1 are really good oil brands. Found that on the first time searching.
Rep Power: 787 Re: Oil Change?????
purolator pureone is good filter. use a torque wrench if youve never tightened bolts before. otherwise a socket wrench is enough. tighten it hard but not too hard (30 ft/lbs), and ONLY when the engine is cold. get one of those "claw" oil filter removal pliars with teeth, because i have a feeling youre gonna need it. fill the new one with a lil bit of oil and put some on the rubber ring before putting it on, and tighten it hard hand tight. make sure to use a new sealing washer for the drain bolt.
Rep Power: 0 Re: Oil Change?????
i am a big fan of fran tough guard oil filters with castrol gtx high mileage, but on the same note my car is a 92 so its little bit older than yours. but i recommend if you have over 100k on it then go with the fran tough guard and the castrol gtx high mileage
mattdoc
03-14-2017 12:10 PM
BootyDo
05-07-2015 04:46 PM
SoNiCcIvIc
03-11-2002 03:37 PM
