"Double engagement on felt going into drive"
Rep Power: 0 "Double engagement on felt going into drive"
Anyone knows what this is? It was written after an inspection by a mechanic. Weirdly the guy didn't verbally mention anything like this when we were talking over the phone.
Re: "Double engagement on felt going into drive"
I know what it is (assuming the trans has no problems).....But the important question is: Do YOU feel anything unusual?
Many mechanics that aren't familiar with Hondas might call it unusual, so do many drivers that aren't used to it.
The feeling is....when you slap the lever into D, the trans will engage 2nd gear, then engage 1st gear a half second later. This is done to reduce the shock of the trans initial engagement, so the car doesn't lurch forward, and is normal for the majority of their cars.
When I first started with this Honda dealer, I noticed it on most of the cars...Now, 9 years later, I don't even think about it at all.
HTH
HTH
Rep Power: 0 Re: "Double engagement on felt going into drive"
Aha I had never paid attention to that! The transmission changes gears smoothly while driving.
Only sometimes if I accelerate very slowly and don't stress the gas pedal I have noticed that: before engaging the next gear the rpm raises (e.g. from 2600 to 2700) briefly... kinda like pressing the clutch while releasing the accelerator with a small delay in a manual transmission. I have to focus on the RPM to feel it, otherwise it goes unnoticeable. Is that normal for a honda auto transmission too?
when the RPMs spike, does the car pull forward or does the acceleration remain constant, it may just be the overdrive kicking on and off.
You may have some slippage in your transmission, when was the last time you dropped the transmission filter and switched the fluid?
I drained the fluid through the drain bolt and replaced the drained fluid in July. I used the honda manual for the procedure which didn't mention anything about transmission fluid filter.
6th gen should only have an internal filter (unless the trans has been replaced already with a quality reman unit, then it may have a small screen filter installed in one of the cooler lines).
HTH
HTH
I noticed the delay years ago with my 05 (shifting into D and trying to leave too quickly) my 2010 is the same. I know to put it into D and wait a short bit before trying to accelerate.
Thanks for explanation about what is actually occuring.
It,s like the jerking on acceleration after decelerating...don't do it. Ease back in slow. A few times getting rattled and you learn pretty quick.
solarpunk70
04-12-2016 11:43 AM
zeshan7616
09-15-2015 12:24 PM
