97 dx d19y7 Electrical Load Sensor replacement help...
Old 09-25-2012
Rtw772's Avatar
Rtw772 is an unknown quantity at this point
I just bought a 97 civic dx 5 spd, d16y7, I used my obd scanner and it's throwing a "P1298" code- electrical load detector circuit high input. My shop repair manual says that the EDL cannot be replaced, the entire engine bay main fuse box must be replaced. Very hard part to find. My idles a little off but the car runs pretty good. Anyone have any advice or suggestions. Any help is greatfully appreciated.
Old 10-18-2012
basstimmy's Avatar
basstimmy is an unknown quantity at this point
Re: 97 dx d19y7 Electrical Load Sensor replacement help...
Did you have any luck with the ELD code 1298? Got the same problem with a '98 Civic
Old 12-09-2015
Lisa Renee's Avatar
Lisa Renee is an unknown quantity at this point
I haveva 2003 civic ex and im.able to simply replace the part instead of whole fuse box not sure what year that changed but hope its as simple for you . From online directions I was anle to fo.it myself.and saved 100.00 shop wanted !!
Old 12-09-2015
Wankenstein's Avatar
Check fuse #15.
Read this: http://honda-tech.com/honda-civic-de...x-eld-2512645/ Solution found on reply #20 in that thread.
CarStuff
12-06-2020 12:52 PM
Thriftmaster
Vancouver
04-28-2015 06:02 AM
tylerginevan
04-27-2015 12:29 PM
BREADFAN
04-15-2015 08:58 AM
thesushiboy
04-12-2015 02:54 AM
Quick Reply: 97 dx d19y7 Electrical Load Sensor replacement help...
