transmission break in?
Rep Power: 0 transmission break in?
Hey everyone, just got my transmission rebuilt..got it back a few days ago actually. I had a reputable shop do it (aamco) so i payed good money for good work and a good warranty. As I am driving I notice that is reving higher than it used to..like in third gear it would usually shift around 2500 rpms now its a little over 3000, on a flat road too..Is this normal as part of a break in period and will it normal out? Or does it sound like something else?
Re: transmission break in?
Late shift is not normal once the engine is warmed up (and assuming the engine itself is operating properly).
Sounds like you need to return to that shop, apparently they aren't done working on it yet.
HTH
Rep Power: 0 Re: transmission break in?
Engine runs great..just something I read. The car did sit for a while before I had enough funds to get the trans rebuilt..but for some reason I thought it took time to adjust with a new transmission
could it be i need to adjust the throttle cable? about 5 months ago I did do some work on the throttle body..or the tps??
(You have this listed under 6th gen, but you didn't say what year the car is.)
These should shift correctly right out of the box, no break in or learning period or anything like that.
If it isn't shifting at the right time, then something is wrong.
But you need to be sure the shifts are really late or wrong:
Please note: Engine RPM vs. throttle position vs. load vs. road speed, all are variables and all contribute to the PCM deciding to make the next shift.
More examples:
Low engine power can make it shift late due to unusually large amount of throttle opening needed to keep it running.
Brakes dragging could be an example too, that could generate the same "late shift" complaint because you would have the throttle opened more than normal to keep your speed up.
Something misadjusted (or bad) inside the trans could exhibit the same late shift symptom, but the cause is now directly related to the trans.
HTH
How many cables on it?
One cable that goes to the gas pedal?
Maybe one more cable for cruise control?
No cable that goes from the throttle body to the trans....Right?
I assume this late shift has only happened SINCE the car was at the trans shop. No, your work would not be related if this is the case.
yeah there wasn't a late shift after I work on the throttle body. It sat like 2 or 3 months, and its a 99 lx automatic..I'm pretty stumped now. I guess all I can do is call them
Rep Power: 787 Re: transmission break in?
i would give it a month or two and you will be towing the car back in for repairs. nobody these days really knows how to work on transmissions anymore.
And they will come up with SOME shady reason to deny the warranty.
my favorite they seem to like is a blanket statement like "you abused it and we can't honor the warranty." then to humor you they will bring your car in the shop, go watch tv in the back for 30 mins, and bring you out a broken clutch plate from some other trans and say see this is what you did to it lol.
knknif
08-04-2015 06:11 PM
Brandon Vlasak
07-25-2015 07:25 PM
Causemo
07-04-2015 07:11 AM
