Throttle Position Sensor
Rep Power: 0 Throttle Position Sensor
I have a 96 d16y8 honda civic and I know the issue with the motor.. I need to replace the Throttle position sensor my question is how do I remove the sensor because there are no heads to the screws.. And once taken off how do I reinstall another one.
Rep Power: 787 Re: Throttle Position Sensor
usually you change the whole throttle body with another one. if you really have the time and patience, you can drill out the rivets (or dremel in a flat line and use a flathead to unscrew them), then replace the tps and use a multimeter to calibrate the voltage readings. not for the average diy mechanic, esp when used whole tb on ebay is $50 or less.
Flipg123
05-08-2015 01:15 PM
Blaster30
04-22-2015 12:21 PM
tkcne
04-18-2015 02:33 AM
