Just to make sure about timing belt!
Rep Power: 0 Just to make sure about timing belt!
I installed the timing belt kit on my 00 ek HB, B16Y7, I have not started it yet, i want to make sure everything as far as timing is correct.
My question is or rather say: after setting all to TDC, install new timing belt, now i have to turn crank counter clockwise, so here is my doubt! is every turn from the point of TDC marking all the way around once, considerate a revolution? and does all marking suppose to line up on every turn?
Thanks for the help in advance.
Rep Power: 0 Re: Just to make sure about timing belt!
Helloooo pple help me out here!
Rep Power: 787 Re: Just to make sure about timing belt!
yes, the markings should line up when you turn it manually. otherwise start over and do not try to crank the motor.
mattdoc
03-14-2017 12:10 PM
