Whistling sound when changing A/C setting
Rep Power: 0 Whistling sound when changing A/C setting
Anyone ever get like a short squeal/whistling sound coming from the Climate control box under the passenger side foot well area?
It seems to do it when I changed the setting on the A/C (like from defrost to another setting).
Rep Power: 176 Re: Whistling sound when changing A/C setting
take out the glove box and look for movements when changing the climate control,
either that rust musta build up somwhere, just cycle alot of times to make it go away somtimes if the car was sitting for a long time and not been used things will creek and squeel
Rep Power: 787 Re: Whistling sound when changing A/C setting
mine makes a creaking sound but remember all the components of the blower are electric and when you change fan position or hot/cold, you may hear some things moving around. over time the grease wears out.
Ever since I replaced my leaky evaporator with a new OEM I've had a whistling sound from that area. It seems to go on and off intermittently, usually in sync with the compressor engaging and disengaging. Others have told me it's normal and to ignore it.
BootyDo
05-07-2015 04:46 PM
Dorval Andre
05-01-2015 09:37 AM
Pir8pete
165
03-06-2009 05:16 PM
