2000 Civic EX battery not charging, alt tested ok
Rep Power: 0 2000 Civic EX battery not charging, alt tested ok
So my 2000 Civic EX with a D17y7 engine is not charging the battery.
I went to check the alternator and found a rusty and almost broken connection (picture attached) , so I automatically thought that was the problem. I removed that plastic covered connector piece and hooked the wire lead strait to the alt. (the connection between the alt and the wire lead was fixed)
The voltage still read only 11.7 while the car was running, and the car died as soon as I disconnected the battery.
So I though the alt was bad and took it to O Riellys and it checked out fine.
Also took it to a Napa, and they said it was fine.
I checked all my fuses, nothing is blown. What else should I check to get this fixed?
Rep Power: 787 Re: 2000 Civic EX battery not charging, alt tested ok
are you sure they are reading it right? how many amps is it putting out? sometimes an alt will test "fine" even tho its only producing 30 amp instead of 60 amp. at idle in park, the voltage should be 13.5-14.0v around there.
Rep Power: 0 Re: 2000 Civic EX battery not charging, alt tested ok
yeah it read 60 amps.
im not getting the 14v at idle so I'm thinking its the wiring. but i don't know where to start looking.
could also be something else wrong with the alt. there is much more to it than a power wire to the battery. its computer controled as well as the alt having multiple parts. lots of places for failure. any engine codes?
rcolosi
04-29-2015 07:48 PM
tattedlariat
04-12-2015 07:55 PM
