removing a crankshaft position sensor
Rep Power: 0 removing a crankshaft position sensor
i know this sounds kind of dumb, but this thing seems to not want to come un plugged. is there a special trick to getting it out? it needs to be changed before i can sell this car, so my starting problems will be fixed. i dont want to have a mechanic do it but if i have to take it in i will. any advice would be appreciated.
Re: removing a crankshaft position sensor
The wires are attached to the crankshaft sensor.
It unplugs up by the alternator/intake manifold corner area.
HTH
HTH
Oh, I get it now.
If you are trying to separate the two halves of the wiring connector, first remove the connector from its mounting tab. On many versions of the connectors, the metal tab locks them together.
Just a guess, HTH
Just a guess, HTH
159
07-05-2015 09:54 PM
Flipg123
05-08-2015 01:15 PM
Blaster30
04-22-2015 12:21 PM
tkcne
04-18-2015 02:33 AM
