Stop-go problem
Rep Power: 0 Stop-go problem
Hey civic owners! I have a problem on my hands. I picked up my car from getting gaskets changed and I'm driving home about a block away at a red light I went to let off the clutch and even it out w the gas smoothly like normal and the car would kind of die down/make a whine noise so I would hav to rev it to about 3 and launch in order for the car to move, same going into second gear.. Any clues? Thanks!!!
Re: Stop-go problem
Sounds like you need to take it directly back to the shop.
They obviously aren't done with it yet.
Rep Power: 0 Re: Stop-go problem
haha yeah exactly what i said, I called them and told them that i had problems about a block away from my house that the car wasnt idling right when i would let off the clutch. They said they didn't touch the transmission nor the clutch. I told them to send a tow truck and they never did, next day wouldnt answer my calls. They call me back a week later asking me what happened. So basically i'm thinking screw that shop and fixing the problem myself just cant figure out the problem
Fluids, Full maintenance inspection, belts and hoses, full tune up, a broken bolt taken out of the valve cover, a valve cover gasket and a oil pan gasket.
Re: Stop-go problem
Well, that "shop" has a huge problem with ethics if they deny responsibility **sight unseen** because "they didn't touch the transmission nor the clutch" when they clearly had a lot of other items apart ON THE ENGINE that affect it, and you are at fault for putting the words "transmission" and "clutch" in the mouth of their phone answerer. Those words gave them an out.
You should have stuck with "this engine hasn't run right ever since I left your shop!" Really, you should have never gone home, you should have turned right around and gone back right then.
IDK...Probably sabotaged.
Lawyer up.
Take copious amounts of detailed notes from the next shop that DOES fix it.
Or
Open your hood and look. Hoses, wires?
Got a check engine light on now? Was it on before? Was it still on when you picked it up?
Did you take it in for this same problem?
Did you ask for this problem to be checked out?
Or did you tell them you wanted a tune up and some gaskets replaced, belts and hoses, full maintenance inspection (whatever the hell that is, I bet they figured you know nothing about cars and could pull a fast one)?
What is wrong with it? I have no idea, and apparently you don't either.
I don't have enough reliable info about how it acts, and you aren't a professional observer that can give a detailed technical description.
Seems to me that you need to seek the services of a competent, trusted professional.
HTH
Lawyer up.
Or
HTH
