98 LX engine swap: D16Y7 to D16Z6 v-tec
Rep Power: 0 98 LX engine swap: D16Y7 to D16Z6 v-tec
My 98 is dead after 300,000+ miles... Threw a rod through the block.
I have another civic available to me for next to nothing. The engine is fine. I'd like to swap motors between the two cars. The donor car is a 95 EX V-TEC. Both cars are standard shifts. The 98 is an LX. Put it this way, when I scrap the extra car and blew motor, I'll make money in the long run. This is how this swap is feasible, it's free...
Can this swap be done? If so, can someone give me a run down on what to look for, what gaskets I'm going to need, if any, and what kind of computer issues should I expect? (Actually, would I be smart to put the donor car's computer in the LX while I'm at it?)
The donor car has a new clutch already in it, so I'm thinking I may as well just go ahead and swap trannies while I'm at it. Good move? I know the LX's tranny is good, should I risk it?
Any help would be much appreciated.
1 Post
Rep Power: 164 Re: 98 LX engine swap: D16Y7 to D16Z6 v-tec
technically this would be illegal. you cant swap an engine thats older than the car your putting it in...but im sure it could be done.
you would need the ecu from the donor car since it is obd1 (i believe) and since the d16z6 has vtec and your lx doesnt. and i would get a headgasket set and a timing belt kit for the engine your swapping.
as for transmissions id keep both. have one for backup or sell it if it still shifts smooth. the z6 tranny is geared closer though im pretty sure.
if your going to want more power when the engine is out is the optimal time to replace rods pistons or anything in the bottom end.
WaryDriver
05-27-2015 05:54 AM
Ninetyatecivic
05-09-2015 07:48 PM
redej2
04-29-2015 01:47 PM
