2001 Idle Air Control Location
Rep Power: 0 2001 Idle Air Control Location
I have been having issues with my IAC. It needs to either be cleaned or replaced which I can do myself if only I knew where it was. I am just hoping that someone can give me a detailed description or pictures of where it is exactly. It's an automatic but I don't know the trim level since it doesn't explicitly say on my car anywhere that I can see. Any help would be greatly appreciated.
Re: 2001 Idle Air Control Location
If you are looking at the engine from the front of the car it will be on your left of the throttle body, attached to the throttle body. If you still have the stock intake, it will be under that. There are 2 black lines (coolant) running to it. There is also a three prong plug into it. three screws take off the IAC...Good luck
