Can't Get the Crank Shaft Pulley Off
Gangsta Sexy
Rep Power: 0 Can't Get the Crank Shaft Pulley Off
Hey guys. Had the timing belt slip on my 2000 Honda Civic LX and am having a really hard time trying to pull the pulley off. Anything i should try to hold the pulley in place so I can pull the bolt out? I tried holding it with a leather belt, and all I managed to do is break the belt.
Also. Am I gonna have to change my valves? The belt slipped about two notches.
Thanks for the help. Ive never really worked on cars. Ive always owned trucks, and my last car was a disaster, so i stayed away from them till now.
Received 1,144 Likes
Rep Power: 485 Re: Can't Get the Crank Shaft Pulley Off
You're gonna need a crank pulley holding tool.. looks like this:
You can usually rent them at an autozone, o'reilly, etc. The crank pulley bolt (at least on my 02) is torqued down to 180 ft-lbs..
as for your valves, I don't think 2 teeth would damage the valves, but a compression and/or leakdown test would tell you if your valves aren't seating right.
Gangsta Sexy
Rep Power: 0 Re: Can't Get the Crank Shaft Pulley Off
I ran a compression test on it last night, and it had no compression, but I was hoping it just because its out of time.
You could but u run the risk of it slipping and gouging your pulley which could make your belts fail prematurely. Your best bet is to get the holding tool mentioned by xRiCeBoYx earlier. Makes it easier(well kinda). Mine was a pain to get off. They are on there real tight(181 ft. Lbs.)
Gangsta Sexy
Alright. I might see if I can weld something up that will work, before I go order a tool. I kinda wanna get the car put back together tomorrow, so dont wanna have to wait for a tool that I have to order.
If u have an o'riellys or autozone near they will rent u the tool for a deposit that you will get back 100%,. Its a tool that they keep on hand cause it is a great one. I dont think they are too expensive too purchase either. I may be wrong on that one tho. Any decent automotive parts store should have it
An O'Reilly by my house had it for rent, but I figured I'd use it a bunch and asked I i could buy it. Ran me $50 with a lifetime warranty.
Yea.. that's just a terrible idea.. That would torque the crank bolt on more. Save yourself pain and hardship (and long-term time and money) by doing it right the first time.
Gangsta Sexy
Putting a wrench against the frame will work, but you have to have a ratchet to make sure it turns the bolt the right way.
I finally did get mine off. I took a chain wrench, and wrapped it around the belt pully for the A/C, and they set it against the frame. And then I used a 3/4" drive Napa breaker bar, and a four foot cheater pipe..and just managed to break my breaker bar. I used a 3/4" electric impact wrench used for semi lug nuts in the end, and it pulled it off afterr hammering on it for a minute.
Skunkone
09-24-2015 04:38 PM
pilebuck13
09-21-2015 10:45 PM
SolidHollow
15
09-13-2015 11:18 AM
