Cat conv.
Rep Power: 0 Cat conv.
I am new and looking for some help. I have a 2000 civic ex. Can anything be done to get the check engine light to go off by taking out internal components of catalytic converter?
Re: Cat conv.
You got a code? What is it?
A fouler won't pass a visual exam when it comes time for emissions testing.
Rep Power: 0 Re: Cat conv.
What do you mean A fouler won't pass a visual exam when it comes time for emissions testing?
The code I am getting is saying Cat is operating below efficiency.
Re: Cat conv.
It is considered "tampering".
Figure out WHY it is bad.
Fix that.
Then replace the cat. Use factory parts.
Re: Cat conv.
Sure, try the no-fouler trick then.
The environment won't care that there is one more polluter running around.
If you do it, expect a drop in gas mileage too.
/hugs a tree
/hugs a tree
I just looking for suggestions If your telling me that I have to stay with the cat to have things working properly. That's all I need to know. Wasn't looking for polluting issues.
Re: Cat conv.
There are plenty of ways to do almost anything wrong. None are guaranteed to actually work as desired.
Like I said, it can and has been done. You can try it and see what happens. If it keeps the idiot light off, then it was dirt cheap.
But don't hold your breath, and don't whine if it doesn't work the way you wanted it to.
Hey if something isn't going to work I do not want to waste my time. Like I said I was looking for an acceptable way around this issue. If there is only one proper way then that is what I will have to go with.
Re: Cat conv.
what would using the non fouler trick have anything to do with gas mileage? It would just read that the air going from the cat is cleaner than the air going into the cat. Its just tricking the ECU. I thought The 2nd o2 sensor has nothing to do with air/fuel mixture?
Re: Cat conv.
On some of the cars, the rear sensor is also used for fuel control, more at certain times than others. So it CAN affect mileage. (I can't tell you which cars do, or just how much influence it has, but I know it is done.)
A huge part of PCM strategy is to keep emissions levels down and keep the cat alive.....think of the PCM as "life support" for the cat. The PCM may want to adjust fuel to keep the cat operating in its efficiency range too, and it may choose to use the rear sensor to do that.
Just sayin'.
winanthony94
09-25-2015 09:05 AM
blizza
09-20-2015 04:09 PM
