2003 Civic Lx Power Window Problem
Old 01-22-2012
CRUDSRUS's Avatar
CRUDSRUS is an unknown quantity at this point
My "03 Civic LX rear drivers side power window will go down but will not go up using rear door switch. Using the rear door switch window works in down position only. Using drivers master switch nothing happens with rear left window but other windows and switches work fine with master switch. The window regulator works fine with power applied using a spare 12v battery. I have a new master switch which did not solve the issue. Checked all fuses-good. Any ideas what could be the problem?
Old 01-23-2012
Re: 2003 Civic Lx Power Window Problem
Wild guess: Is this door used a lot?
Testing, following a wiring diagram is the way to find out what the problem is.
I would probably look for a broken wire where the harness goes between the door and the body, if testing told me there is a wire problem.
Old 01-24-2012
CRUDSRUS's Avatar
This should have been posted in the 7th generation area but thanks for the reply. Where can I find the wiring diagram for the Power windows? I have someone who can help me with troubleshooting but a diagram is needed
Old 01-24-2012
Service manual
Google image search
AlldataDIY
Mitchellone
Maybe Autozone for books
Local library, they might have a subscription to Alldata or Mitchell
I cannot hotlink my info, it's subscription only.
Old 01-25-2012
CraigW's Avatar
PM with an e-mail and I can get it to you.
Old 09-06-2012
wspeid's Avatar
wspeid is an unknown quantity at this point
Were you able to fix your problem? I have the identical issue! I was wondering if it was related to my battery dying because I've heard of computer problems after battery disconnects.
Bill
Old 09-06-2012
Bill
Can't be related to a dead battery UNLESS your battery is still dead, and all the windows don't work.
Dorval Andre
General 7th Gen
28
07-21-2022 05:53 PM
usajags84
05-10-2015 08:11 AM
Ian SFBA
Interior DIY
04-25-2015 02:25 PM
Fastfebur
04-22-2015 01:37 PM
deus-ex
04-13-2015 12:29 PM
Quick Reply: 2003 Civic Lx Power Window Problem
