Replaced tie rods and now can't get it aligned!
Rep Power: 0 Replaced tie rods and now can't get it aligned!
I swapped out the tie rods on my 98 EX yesterday and today took it to the dealership to have it aligned. They claim that it will not take the alignment due to the rod ends already being at their maximum adjustment. Wheels are toed WAY in. They claim it's because the rod ends were installed backwards (left and right reversed) but I'm SURE they are on correct (replaced old ones at identical orientation and compared to service manual photo).
Would reversing tie rods even have this effect?
A fix to this would be shorter tie rod ends...how do I find a set?
Prelude Owner
Re: Replaced tie rods and now can't get it aligned!
Yes some cars have rods that are different lengths so if they were backwards then it could make it so it won't align. If you got the correct rods then you shouldn't need to find shorter ones. Maybe where you got the part from gave you ones for a different year or model.
Rep Power: 0 Re: Replaced tie rods and now can't get it aligned!
The mechanic claims the direction the curve faces affects the overall length of the rod, so reversing them changes how far they actuate the steering. Is this BS?
Prelude Owner
Try to adjust the toe yourself and see of you can get it in further. I don't know why else you wouldn't be able to get them in enough to adjust the toe unless they were the wrong ones or on the wrong side.
I do remember they were turned in as far as they could go. I still have the old ones. Guess I'll check their lenght against the new ones. God I'll be irritated if the wrong parts are on there...
Ok, they're the right parts, on the right sides. Even have the "idiot proof" L and R stamped on them. They're turned in as far as they'll go (rods are bottoming out in the tie rod ends). I don't know how I have the means to determine they're on correctly but a HONDA TECHNICIAN does not.
I can't solve this, but I think I'd better find a different mechanic.
Received 1,440 Likes
Rep Power: 338 Re: Replaced tie rods and now can't get it aligned!
did you turn the rod itself so as to make the inner ones all the way in?
inner and outer had reversed threads, so you can rotate them and change length without removing from the car.
so remove outer ones, rotate rod and make them go all the way in, then install outer ones and rotate them all the way in. them tighten the outer/inner to the steering box/struts.
now you can start rotating rods until you get a decent toe.
Ok, just so I am clear...I thought inner rods just spun freely. Are you saying if I just popped the ball joint, left the outer on the inner (locked in place), and spun it, it would actually screw into the rack?
woops...
i was actually thinking on my older car.
make sure both sides of the tie-rod ends are all the way in - the one to the rod and the other side - if they are not, they will off-set.
pheaton
05-04-2015 08:26 PM
oneheadlight
04-29-2015 11:30 PM
thesushiboy
04-12-2015 02:54 AM
