96 civic dx, was this the proper way to install a motor mount?
Old 07-13-2011
GummyBear's Avatar
GummyBear is an unknown quantity at this point
basically someone i know couldnt get one of the bolts off the front left lower motor mount. so he cut a small hole in the wheel well(not sure if this is the proper term) to get to the top nut so he could use a wrench to hold it in place to get the bolt off. then he pushed the metal part back in place and put silicon to keep it sealed. it probably wasnt the best way to do it but considering we had time constraints, tbh i didnt know he was going to cut a hole until he had alrdy started... just wanted to know your thoughts. will this cause any other problems? probably not but im not a expert mechanic... still kinda novice.
also im trying to figure out why my car kicks when i shift to reverse, could it be i have a tranny problem? or is it a motor mount? the only one i can visually see that was ripped was the one i just replaced.
Dorval Andre
General 7th Gen
28
07-21-2022 05:53 PM
MN-02-CivicEx
28
05-02-2015 09:11 PM
bsmiley
04-27-2015 01:27 PM
Gunner
Engine DIY
10-06-2012 12:37 PM
toastyghosty
32
12-26-2001 02:03 AM
Quick Reply: 96 civic dx, was this the proper way to install a motor mount?
