98 Civic Randomly misfires and stalls
Rep Power: 0 98 Civic Randomly misfires and stalls
This has been an issue for about a month now. My car will drive fine for a while then all of a sudden the CEL comes on the revs start going up and down (misfire?) and after a little bit it will stall. After it dies I can start it back up again without a problem and the CEL goes off, although it usually starts misfiring again pretty quickly after that. If I let it sit for about a day it usually runs fine again until it warms up for a while. I have replaced the ignition switch, spark plugs, wires, rotor, and cap but none have helped yet. No mechanics have been able to figure it out yet because they haven't gotten it to stall, but I'm going on a road trip soon and can't have it die out on me. Any help is very appreciated
Re: 98 Civic Randomly misfires and stalls
You can get one off amazon for $30. http://www.amazon.com/Autel-MaxiScan...5865102&sr=8-1
Rep Power: 0 Re: 98 Civic Randomly misfires and stalls
Sounds. like an IACV valve gone bad the idle, stalling; try cleaning it. The IACV is on the back of the intake manifold
Good luck
Good luck
Rep Power: 210 Re: 98 Civic Randomly misfires and stalls
Car warms up, car mis-fires- sounds like a bad headgasket. Get that scanner or have the auto parts store scan it for you. Usually it's free. If it just reports a mis-fire I would think it is the headgasket just by the symptoms. Of course, you would need to test for a bad headgasket before replacing it.
rcolosi
04-29-2015 07:48 PM
Blaster30
04-22-2015 12:21 PM
ashleymmackey
04-18-2015 09:48 PM
