always blows hot air no matter what...why?
Received 1,148 Likes
Rep Power: 485 Re: always blows hot air no matter what...why?
wait, actual hot air, as if you turned on the heater to full blast? or hot air as "it's not cold like a/c should be, but it's blowing car-room temperature" air?
Rep Power: 0 Re: always blows hot air no matter what...why?
with controls on cold it still blows just as hot as when it was on the hot setting. not sure when the coolant was changed, i just got the car a few weeks ago. could that be a cause?
could be a fault in the switch or solenoid, or a stuck valve that allows your engine coolant to go to the heater core. Sounds to me like it's stuck in the open position, sending coolant through your heater core. My theory.
Live for the Twisties
Rep Power: 260 Re: always blows hot air no matter what...why?
If you just got your car a few weeks ago and you don't have a complete service history the first thing you need to do is change all you fluids; coolant, ps, brake, transmission and oil.
The first thing I would do before anything else is change your coolant, because that may very well solve the problem and it should be done anyway. If thats not the solution then theres a problem related to the heater core like Josh said.
sk8ermommie
06-09-2015 10:41 PM
mrohitredd
05-30-2015 06:51 PM
g4384063
05-30-2015 11:21 AM
jc33312
05-12-2015 03:17 PM
