Help finding whats wrong with my 97 Lx
Rep Power: 0 Help finding whats wrong with my 97 Lx
Ive got a 97 Lx and sometimes when i step on the gas the car will hesitate. It will go but you pretty much have to floor it to get it to shift. When I come to a stop, the car will idle really rough. Sometimes when you drive it it will do it and sometimes it wont. When it does hesitate the car will usually come out of it for a while and drive normal and idle like its supposed to. What could be wrong?
if it makes a difference, there is no cat. The pipe fell off about an inch or two on the front side of the cat, so no i have a straight pipe that ends under the drivers seat. could no cat be causing these symptoms?
Rep Power: 210 Re: Help finding whats wrong with my 97 Lx
Sounds like an exhaust restriction (cat going bad). Take it to Autozone and have them scan for codes. Post the specific code here and we may be able to help.
Pull the OBD I code out of the service plug. It's under the kick panel on the right side of the car. Inside, under the glove box. It's usually light blue
Jump the 2 wires with a paper clip and turn the key on. Read the codes. Do a google search to find out how to read and interpret the codes. It's easy.
Post the code here.
Rough idle. Hard shifting. Hesitation.
Sounds like a throttle position sensor to me. But check the codes. It's really easy to do.
Post the code here.
Post the code here.
Post the code here.
Received 1,440 Likes
Rep Power: 338 Thread
Default_Slayer
Electrical DIY
12-04-2022 07:56 AM
GhettoCivic
11-12-2001 03:15 PM
Aznnp77
11-08-2001 04:49 PM
