help with trouble codes
Rep Power: 0 help with trouble codes
hey whats up? i need help please interpretling the trouble codes for my 1996 honda civic. i am a noob,but i have tried investigating this on my own,through google and other search engines.please help if you can. if possible i need specific instructions on how to fix these problems.anyway here are the 5 codes my engine is throwing. p0122 circuit low in input. p0500 speed sensor malfdunction. p1298maufacturer fuel and air meter. p0135 02 sensor bank 1 sensor1. p0141 heater circuit malf. bank 1 sensor 2 any help would be greatly appreciated. thanks.
ok the last 2 are o2 sensors... those will just have to be replaced.. you can rent the special tool at autozone;... speed sensor malfunction.. i'd say replace the speed sensor and go from there.. i'd start there the other 2 codes sound like they're related ot the others... also, check thoroughly under the hood to make sure you dont have any burnt wires.. did all this happen at once? or jus tover time? the front o2 sensor will make your cr run like *** so fix that one first...
Civic15
18
09-19-2017 07:48 PM
Dangerousjordan
07-30-2015 11:19 AM
Green02civic
07-27-2015 10:48 PM
liagreenhalgh92
07-21-2015 01:31 PM
