quick DIY - Strut Boot Fix
Old 12-17-2014
06 EX Mild Mods's Avatar
06 EX Mild Mods has a spectacular aura about06 EX Mild Mods has a spectacular aura about06 EX Mild Mods has a spectacular aura about
The strut boot dislocated from my 06 EX, this was a 2 person 4 hands job. I pulled the boot down while my brother applied the tye wraps. A temporary fix for old struts, we'll see how long this lasts but it is cheap and easy to replace if needed and helps the strut seals last longer.
Images didn't work without the IMG pre and suffixes.
Old 12-18-2014
CraigW's Avatar
Re: Strut Boot Fix
My boots are like that as well on 2010..... Are they supposed to be affixed at bottom ???
Old 12-18-2014
Re: Strut Boot Fix
Yes they are to keep the road grime off of the strut shafts which wears out the seals where the shaft enters the strut body. I keep hearing a cashucking sound going over bumpy roads, which was caused by the lose end of the boot rubbing over the clip that is suppose to hold it in place. Look carefully just below the bottom spring in the picture for this clip. The boot was pulled over this and then tightly tye wrapped.
GolNat
Suspension DIY
05-12-2022 06:49 AM
Bugman1400
05-15-2015 08:10 PM
toastyghosty
37
06-10-2002 01:07 AM
manicEL
12-10-2001 06:33 PM
MooCoW
11-09-2001 05:22 PM
Quick Reply: quick DIY - Strut Boot Fix
