Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
Reload this Page
help on terms
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
LinkBack Thread Tools
Old 05-28-2003   #1 (permalink)
iLLuMiNaTi
Senior Member
iLLuMiNaTi's Avatar
iLLuMiNaTi is an unknown quantity at this point
help on terms
Hey,
can anyone help explain to me what all these terms mean? (or a link to some kind of site that has all the definitions for each thing)
1. Volume Acoustic Suspension
2. Total Q (Qts)
3. Electrical Q (Qes)
4. Mechanical Q (Qms)
5. Xmax
6. F3
7. Qtc
Any type of help would be cool. I know i'm prolly asking a lot, but just a link to a website would be nice.
thx in advance
iLLuMiNaTi is offline   Reply With Quote
Sponsored Links
Old 05-28-2003   #2 (permalink)
LudlamTheory
i boogie for the raindrops
LudlamTheory's Avatar
i dont have much time right now to explain, i'll finish later when i get to my books and such, but off the top of my head, Volume Acoustic Suspension, more commonly known as Vas, is a way to measure the stiffness of the suspension of a driver when you push it in. what it does, is it takes the amount of pressure it takes to push it in, and it translates it into a body of air which has the same pressure to push in. which is why its measured in liters of cubic feet as opposed to kPa or mm's of Hg or atm's or torr's or any other measure of pressure. im probably slightly off, but oh well
xmax is the distance from rest that a cone travels. xmax, or maximum excursion. how far the cone excurts.
only other thing i can tell you off the top of my head is that Qts is derived from Qes and Qms, so its not its own unit.
F3 i believe may be a box tuning of the ripple, and qtc i believe is alignment. ill explain later...
LudlamTheory is offline   Reply With Quote
Old 05-28-2003   #3 (permalink)
playaz0429
Senior Member
playaz0429's Avatar
playaz0429 is an unknown quantity at this point
hold on, im gonna go to college for 5 years really quick and then ill be back to tell you. lol, why??
playaz0429 is offline   Reply With Quote
Old 05-28-2003   #4 (permalink)
iLLuMiNaTi
Senior Member
iLLuMiNaTi's Avatar
the reason why i posted this question was because im simply trying to learn as much about I.C.E. as necessary to be able to build a nice sounding system. As I was browsing through the Xtant website, i found a couple of specs on it, and i didn't know what they meant so i came here to ask what those terms meant.
Also, if you know of any good books, that can explain a lot of ICE stuff, please tell me the title or something.
Old 05-28-2003   #5 (permalink)
Ed
Ultimate Member
Ed's Avatar
Location: Deathie Elaine and Pecosa Land, Hudson, Ohio, US
here's the first website i found on a quick search, i dont' know how good it is http://www.caraudio.la/glossary.htm
Ed is offline   Reply With Quote
Old 05-28-2003   #6 (permalink)
LudlamTheory
you want a cool book? get the loudspeaker design cookbook.
i promised i'd be back to answer everything, so here it is:
Vas: The volume of air having the same (acoustic) compliance as the suspension of the woofer.
Qts: The total (sum of electrical + mechanical) "Q" of a woofer.
Qes: The electrical "Q" of the woofer.
Qms: The mechanical "Q: of the woofer.
Fs: The free air resonance of a woofer.
Xmax: The ELECTRICAL LIMIT of the one-way movement of the woofer. This represents how far ELECTRICITY can move the woofer, NOT how far your hand can move it!!
SPL: The amount of sound pressure (measured in decibels) that the woofer will produce given ONE watt of power measured a distance of ONE meter.
http://www.eatel.net/~amptech/elecdisc/caraudio.htm
Old 05-28-2003   #7 (permalink)
WhiteRabbit
Ultimate Member
WhiteRabbit's Avatar
WhiteRabbit should not be questionedWhiteRabbit should not be questionedWhiteRabbit should not be questionedWhiteRabbit should not be questionedWhiteRabbit should not be questioned
http://www.mobileaudio.com/rac-faq/rac-faq_4.html is my personal favorite basics site.
but to be honest, these terms really dont mean anything as far as building a nice system is concerned, and there are other definite important concepts to get down before you should care to figure out how each of these paramaters can affect performance!
WhiteRabbit is offline   Reply With Quote
Old 05-29-2003   #8 (permalink)
iLLuMiNaTi
Senior Member
iLLuMiNaTi's Avatar
thanks a lot you guys!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Amp Wiring 2k1civic coupe
DIY: Head unit install
Sound Deadening DIY
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
MTX Jackhammer! Don't they know when to draw the line?
DIY: Custom Trunk II !with access to spare tire!
*** The big I.C.E. & Electrical sticky (DIY's, links, POSTING GUIDELINES, more) ***
HID in TYC setup. With no projector conversion. Video on pg 17.
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
