Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 04-03-2003   #1 (permalink)
syndrome
Senior Member
syndrome's Avatar
syndrome is an unknown quantity at this point
Send a message via AIM to syndrome
Rear deck/back panels removed... what are the do's and dont's back there?
The subject is a little vauge but hopefully my message will convey what I'm asking much better.
I removed the rear deck and all the necessary panels yesterday and I'm leaving them off for a couple days while I dynamat certain places during my freetime. I'll make a little list of concerns from here on:
1) White moisture sheild on side panels - do I need these? can I just spread dynamat on the inner car metal its sheilding instead?
2) Deadening rear deck - With all the holes and clips and bells and whistles involved on that thing it is a straight biznatch to spread mat over.. what can I do short of putting a protected mat on top of it and seeing where I need to cut holes before I sread it?
3) The black garbage bags/air tight bag containing (insulation?)/and styraphone blocks in both sides of the side panels - Ok.. what purpose do they serve? Ill leave them alone if I have to but if they can go I'll toss them happily.
4) Flap vents in trunk - They rattle all over the place even when I barely have the volume up, fortunitally I don't hear it inside but its a little annoying outside around my car.. what are they and can I do something to shut them up.
5) Plastic cover over the front seat mechanisms - can I toss those too? thin plastic like that could be nothing but trouble.
6) Any reccomendations on where else to spread mat - Im willing to deaden anywhere, I got enough mat but I dont want to put it somewhere that dont need it.
Whew.. ok, I know I left out a couple things, but if you have opinions or answers and such pleaseeee offer them up.. Thanks guys.
__________________
Kicker L7 12" Ported Sub @ 38hz
Kicker RS6 Components
Kicker KX600.1 Sub Amp
Kicker KX300.2 Component Amp
Pioneer 840 MP3 Player
Pioneer 7600 EQ
Pioneer Changer
Audiobahn ALD30X Line Driver
Audiobahn 4/8 Awg Wiring Kits
RaamMat'd Everything
syndrome is offline   Reply With Quote
Sponsored Links
Old 04-03-2003   #2 (permalink)
alex053
alex053's Avatar
1. I pulled it off, filled that entire area with expanding foam and put a layer of mat over the top, poked holes for the panel to clip back on.
2. it is a bitch. roll the mat on in sections and poke holes from the bottom.. this is the easiest way.
3. see step one for what i did with those
4. I still have duct tape over it from when i was spraying in sound deading. Use anything from tape to dynomat to fiberglass to seal this up
5. be sure to put it on the wheel wells behind that white vapor barrier. Lost of road noise in that wheel well. I have mat everywhere so im not sure if there are any places i didnt need it.
__________________
2006 Smoke Nissan Titan LE
2002 IBP Lexus IS 300
2006 Yamaha Rhino
alex053 is offline   Reply With Quote
Old 04-04-2003   #3 (permalink)
WhiteRabbit
Ultimate Member
WhiteRabbit's Avatar
WhiteRabbit should not be questioned WhiteRabbit should not be questioned WhiteRabbit should not be questioned WhiteRabbit should not be questioned WhiteRabbit should not be questioned
Send a message via AIM to WhiteRabbit
yup, best way to ensur eyou put it where you need it is to play music loud back there and listen for noise. and when you are ready to put yrou car back together put the pieces in one at a time and do the same thing, to ensure you get no rattles as you assemble yoru car.
if you go step by step, you ensure a rattle free car!
WhiteRabbit is offline   Reply With Quote
Old 04-04-2003   #4 (permalink)
Mystic3030
Yup, i'm an A$$hole.
Mystic3030 has a spectacular aura about Mystic3030 has a spectacular aura about
Send a message via AIM to Mystic3030 Send a message via Yahoo to Mystic3030
OK, to answer the question about hte plastic bags and styrofoam....
Black plastic bag is full of polyfill, it and helps with road noise. Leave these in place.
The white styrofoam is impact protection, and it is against DOT regulations to remove them. You are subject to a $100,000 fine if you get into an accident and they are found to not be in the vehicle. I would reccomend you not remove these either.
BTW, not pulling that stuff out of my ass, I called the Honda dealer, because I wanted to just take the styrofoam out too.....not a good idea.
Mystic3030 is offline   Reply With Quote
Old 05-29-2003   #5 (permalink)
armageddon
Member
armageddon's Avatar
armageddon is an unknown quantity at this point
I can hear that flap from the outside also. I havent looked much for it but it would be nice to take care of it. Can you guide me to the "flap"? Also my tail lights rattle bad. any suggestions??
armageddon is offline   Reply With Quote
Old 05-29-2003   #6 (permalink)
WhiteRabbit
Ultimate Member
i might try removing the taillights, lining them with weatherstripping, then cranking them back on. that shoudl help the rattle, jsut liek yoru liscence plates.
flap is on the left side of teh trunk (as you are standing outside the trunk looking into it) near teh skin of the car.... if you take out the sidepanel of carpeting back there, its pretty hard to miss.
Old 05-29-2003   #7 (permalink)
armageddon
Member
armageddon's Avatar
thanks so much! I guess I was just too lazy to go hunting for it. I will try the weather striping.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
