| diy diy. here ya go.
step 1. where the handle is on the inside there is a little clip with a slit on the top of it. take a itie bitie flat head screw driver and pop it out twords you, and take out the two screws behind it. and then unplug the door lock and the door latching piece that looks like a coat hanger kinda thing(its held on by a little clip just use a flat head screw driver to move it off the piece). take off the piece behind the outside mirrors. it just pulls out it might take a little force, but it will come.
step 2. where the arm rest is the part of it on the inside of the car, not the top of it but the side. that piece of plastic is only cliped on. pull out on it near the back and it will kinda unclip itself. there is a little slit under the front of the arm rest just like in step one that releases one of the clips but its hard to get too. you can get the piece off by taking the back part first and it will just pop off.(this is a hard piece of plastic, not the back piece of the arm rest)
step 3. there are two screw visible on the arm rest after the plastic piece is removed. take them out. also if you have power widows unplug the big cord looking thing.
step 4. there are 2 more screws in the arm rest they are a little hiden but they are there. take them out.
step 5. there are 7 clips that hold the whole pannel on. just wok your way around the door starting where the speaker is and once its free from all clips slide the whole door pannel straight up and your done !!!!!!!
i am pretty sure the speaker wiring is the same for the front door speakers. if not just tell me
hope this helps a little. what ya think |
