Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
Reload this Page
*** DIY OF THE MONTH *** Fiberglass kickpanels
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
LinkBack Thread Tools
Old 05-03-2005   #61 (permalink)
J187
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
6"4"3" meaning 3 ways? If that's what you mean yes, they do. But I'm not sure if any of them work the same as CDT's system. What CDT audio's does is allow you to add a 3rd speaker to any one of thier existing component sets on the same amp channel. So for instance, if you had CL-61As, you could buy their CL series sixoctave set for only $99, you get 2 4" fill speakers and a tunable xover and you wire the whole thing right inline with your existing components and tune the 4" to pick up the gaps left by you component xovers. I'm not sure if Boston, dyne or DA has anything like that, I've never noticed. I know Boston's 65.3 set was a simple 3-way with a 6.5", a 4" and a 3/4" tweeter. - Awesome sound but retailed for like $750. Ouch. They weren't competition for Focal! If any other companies do have a add-on 3rd speaker system that ties into the same amp channel, I just haven't noticed.
J187 is offline   Reply With Quote
Old 05-03-2005   #62 (permalink)
ex_03
Godlike member
ex_03 is on a distinguished road
Yea I thought they all could be amped on one channel like that.Hmmm, never did any sets of any of them becuase they were bank, like you said.
ex_03 is offline   Reply With Quote
Old 05-03-2005   #63 (permalink)
J187
J187's Avatar
Well I know with the BAs, you had to replace the whole crossover with the 3-way crossover. Rather than running 2 crossovers on one channel like the new CDT. So if you were running pro series comonents, I think they were called 6-5s, you would have to take them out and replace the whole setup with a 3-way xover and 4", sold only as 3-way. That's why I think the sixoctave system is kinda neat. Add-on style. Not only were they expensive, but the BAs tweeters made my ear's bleed. I think 3 dogs died on my block the day I installed mine.
Old 05-06-2005   #64 (permalink)
WhiteRabbit
Ultimate Member
WhiteRabbit's Avatar
WhiteRabbit should not be questionedWhiteRabbit should not be questionedWhiteRabbit should not be questionedWhiteRabbit should not be questionedWhiteRabbit should not be questioned
I will post as I think of what went wrong with those kicks.
#1 Aesthetically, it was neccesary to flush mount them. period. didnt matter that it was an experiment, they just didnt look good surface mounted.
#2 vented. vented, vented, vented! needed a hole in the bottom that mashed into the carpet to let some air out. this I later corrected and added clay. Helped.
#3 the midbass box drew bass guitar and kickdrum to the right. it was a failure from quality of sound standpoint. kinda fun to drive around with, though.
#4 its SUPER important to realize your friends are idiots and completely untrainable. You cannot expect for them not to put their foot through your kicks, even after you tell them three times. your grills better be foot-proof.
#5 the tweeters are in front. they need ot be farther away than the mids. tweeters are much more distance sensitive than midranges and especially midbasses. I had problems in this car with high frequencies that were deep in the stage still sounded like they were right in front. moving the tweets back would have helped!
#6 its raining, and my tweeters are in front! rain killed my drivers side tweet when we had the boatloads of rain that winter. having them far back would have rendered them weather inacessible! (and saved me space).
#7 the tweeter shuld have also been on its own seperate baffle. the tweeter had its own dispersion pattern, and my stage would have GREATLY benefitted if I had the opportunity to position all four speakers individually.
#8 I dont like how the kick spills out on top of the door sill. aesthetically, the only way Ive been able to come up with a solution is to use bondo and paint the kicks to match as closely as possible. I'm open to suggestions for my new grill show to combat this problem! I suppose another option is to mod the stock plates, but I like the ability to revert back to stock. anyone who has seen my car with the back seat removed and the three 15's are always shocked to see the backseat back in my car, as if nothing was ever amis!
WhiteRabbit is offline   Reply With Quote
Old 05-06-2005   #65 (permalink)
ncirom2003
ncirom2003's Avatar
good job but im not liking the way it looks, although it seems like your a guy more about function than form and thats good.
ncirom2003 is offline   Reply With Quote
Old 05-07-2005   #66 (permalink)
WhiteRabbit
Ultimate Member
you are right, aesthetics are a severe problem with these kicks. physical depth of the kicks was a major issue, along wiht using such a large diameter speaker. as I recall, these drivers wont even fit into Q logics, by a massive margin. However, I feel ive addressed the aestehtics concerns in the above. breakdown though:
good: hood release latch
bad: carpeted, spill out over the sill, too huge, tweeter extended forward, drivers not flush mounted.
what were the other bads you saw? your next post could radically change the next kicks someone here designs, for the better
Old 05-07-2005   #67 (permalink)
ncirom2003
ncirom2003's Avatar
i figured id just show you were id trim it to make it flow a lil better,
nvm cus the files are too large and im past due for sleep lol what i would do is trim where it overlaps the doorsill so it stops where it meets the sill, then trim it so it goes straight down then curves sharply and extends to the gas cap lever(goes under that plastic to hide the seam) then id extend it on the side also and trim it so it curves slightly out like it does but a little less and get rid of the bumpiness of the edge, and match the carpet. it looks nice but seeing that you built it good i know you couldve definately done better either way id also angle it so the tweets are closer to the ground and the top of the speakers are tilted back towards door more then take the whole piece of wood they are on and move it in that direction maybe an inch or a half. this is what im thinking for looks but obviously you had better things on your mind and if i knew how to detect hafl the things you talked about it id do it the same way u did
oh and thank god you removed teh sub from the passenger floor lol
Old 05-07-2005   #68 (permalink)
WhiteRabbit
Ultimate Member
yes, thats the ideal spot for the spillout over the sill. the problem is, the thickness of the stock panel is about the thickness of standard vinyls! so if I were to fiberglass right to the same distance out as the stock panel when I vinyl it still sticks up like the carpeted ones do! how to get it flush without paint? I have no idea!
Old 05-07-2005   #69 (permalink)
J187
J187's Avatar
Quote:
Originally Posted by LudlamTheory
well done.... too bad i paid money for my kicks
My how things have changed since 03', Can you imagine what he might have to say now?
Anyway, I think you did a pretty good job with what you had to work with, I mean the drivers are huge and the tweeter is a monster. I would have suggested you made a border around the baffle and used a one-piece grill to cover the whole thing. Also, maybe vinyl would have been better too. Like I said, I think maybe part of the problem is you picked some what of a PITA set of speakers to work with. A more conventional set of components would have been easier to aim, baffle and flush. I think there are two morels of the story here fore people to take away.
1. Take your time with the planning stages and the aiming of your speakers even if the desire to jump right into the building process plagues you.
2. Do not set the bar too high for your first project. Not very often at all do you end up liking and keeping you first attempted project. Noone has ever learned anything from success.
I knew that the tweeters would not fit in the sails,
Umm, I don't think the tweeters would have fit in the stock 6" door locations!
Considering all the problems you had imaging it, 2 weeks with still minimal success, perhaps you would have been better off leaving the stage down low with perfect rt and lt and using an imaging tweeter on the dash to bring up the stage?
I'm in the process of building kicks right now. When I'm done, I'll make it into
a DIY as well.
Old 05-07-2005   #70 (permalink)
fonto
The LA Clipper
fonto's Avatar
what would be the cons of putting tweets in the sails, and leaving the midrange in the kicks?
fonto is offline   Reply With Quote
Old 05-07-2005   #71 (permalink)
MegaHurtz
MegaHurtz's Avatar
Stickied as the first winner for DIY of the month!
MegaHurtz is offline   Reply With Quote
Old 05-07-2005   #72 (permalink)
WhiteRabbit
Ultimate Member
more like DIY of the week. doesnt need to be stickied long before it gets filed away in your all encompasing ICE sticky.
fonto, I had problems putting my tweets in the sails with the speaker distances. corractable using time alignment, but for the passenger, that made all the noise the stereo produced sound like it was coming from the right a-pillar.
to be fair, though, I was using very very wide range drivers up there. I think it could work if your tweeters were designed to be filtered very very high, such as LPG 26na's or other inexpensive drivers.
I cant wait to see your kick DIY, j187! im sure mega will put it right next to mine in the diy listing, ill probably vote for it cant wait to see what you are gonna do with those six octaves
Old 05-07-2005   #73 (permalink)
J187
J187's Avatar
more like DIY of two years ago, revisited
Old 05-07-2005   #74 (permalink)
MegaHurtz
MegaHurtz's Avatar
diy of the month cuz i am too lazy to change it every week
Old 05-08-2005   #75 (permalink)
MegaHurtz
MegaHurtz's Avatar
btw rabbit, what tweeters are those in the kicks?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Amp Wiring 2k1civic coupe
DIY: Head unit install
Sound Deadening DIY
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
MTX Jackhammer! Don't they know when to draw the line?
DIY: Custom Trunk II !with access to spare tire!
*** The big I.C.E. & Electrical sticky (DIY's, links, POSTING GUIDELINES, more) ***
HID in TYC setup. With no projector conversion. Video on pg 17.
Site Supporters
aluminum radiator
Honda car spoilers
Powered by vBulletin® Version 3.6.8
