Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 12-21-2002   #1 (permalink)
Rollin0n18s
Guest
Posts: n/a
I hope someone can help me with this question?
I was wondering what the amp rating on a stock 2k1 civic alternator and what would be some of the benfits of upgrading the alternator to higher amp To remove this ad, register today for free or log in if already registered!
Sponsored Links
Old 12-22-2002   #2 (permalink)
OmegaBlue2k1
Member
OmegaBlue2k1's Avatar
OmegaBlue2k1 is an unknown quantity at this point
Send a message via AIM to OmegaBlue2k1
Answer to your first question would be in your owners manual, i know that doesnt help but i dont want to spit out a number if im not sure. (i want to say something like 120 - 140 amp though, rough estimate)
Second question would be that your battery stays fully charged during normal driving conditions, and you will not notice wuite as much of a power loss when using multiple high draw components (turning on headlights, rolling down windows and opening your sunroof while honking your horn and blasting your 600 watt stereo system all at the same time, oh yea, all while using your windshield wipers and defrosting your rear window)
OmegaBlue2k1 is offline   Reply With Quote
Old 12-22-2002   #3 (permalink)
GhettoCivic
Member
GhettoCivic is an unknown quantity at this point
- Not exactly sure here, but I think that upgrading to a high output alternator will take a way a little bit of horsepower (the opposite of an alternator pulley adding horses because the alternator isn't putting out as much power)
The only reason you would need to get a higher output alternator is if you are running a BIG sound system, or a lot of ICE.
GhettoCivic is offline   Reply With Quote
Old 12-22-2002   #4 (permalink)
Jalegr
Member
Jalegr is an unknown quantity at this point
Dead right GhettoCivic. You would also cut into your Miles Per Gallon with a high amp alt. I would run all the electic goodies with the stock alt and check that the battery will hold the volts that it does without all the goodies on before you go and change out the alt.
Food for thought.
Would the factory wire harness (and all the fusible links built into it) carry the power of a high output alt if you did go with one?
Jalegr is offline   Reply With Quote
Old 12-22-2002   #5 (permalink)
Abstract
Member
Abstract is an unknown quantity at this point
Send a message via AIM to Abstract
80 amp alternator stock, upgrading will not hurt your fuel or horsepower.
Abstract is offline   Reply With Quote
Old 12-23-2002   #6 (permalink)
LudlamTheory
i boogie for the raindrops
LudlamTheory's Avatar
Send a message via AIM to LudlamTheory
80 amp cold, 70 amp hot... hot rating is more realistic since your car will be running
__________________
the revolution is over, and so as to not inconvenience anyone, nothing has been changed.
thank you.
LudlamTheory is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
