Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 11-22-2002   #1 (permalink)
MangoEX
Just Be
MangoEX's Avatar
MangoEX should not be trusted
Send a message via AIM to MangoEX
02 Civic Coupe EX front door speaker removal, help
How do you remove the speakers? i ordered a component set.. and i was wondering how its removed cause i didnt see any screws holding that plastic baffle thing to the door, does it pop out? is there 4 screw holes for the 6 1/2"? Thanks!
oh and how do i put tweeters in place of the stock tweeters? do i need new plastic caps like from an LX coupe so i can redrill the hole? or can i use the existing EX tweeter housing?
MangoEX is offline   Reply With Quote
Sponsored Links
Old 11-22-2002   #2 (permalink)
STang57
Member
STang57 is an unknown quantity at this point
Send a message via AIM to STang57
to remove the door speaker...at the top use a flat head or something and push down...theres a metal clip behind the tab at the top. while pushing down on it pull the top out.
to change tweeters...take off the whole triangle sail panel. in the back of the tweeter should be a little screw holding in the stock tweet. you can still use the stock garnish to house an aftermarket 3/4" tweeter but may need to mod.
STang57 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
