Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-22-2002   #1 (permalink)
Bellz
Diamond Member
Bellz's Avatar
Bellz has a spectacular aura about Bellz has a spectacular aura about
Send a message via ICQ to Bellz Send a message via AIM to Bellz
DIY: Rear Speaker Install for Coupe
For all the n00bs that haven't ripped out the rear speakers![IMG]i/expressions/face-icon-small-wink.gif[/IMG]
1. Remove one (1) 10 mm bolt from space between center of seat bottom and seat back cushions. Pull front edge of seat bottom upward to release hooks and remove (Figure 1).
2. Fold down both rear seat backs. Fold back carpet flap on back of passenger's side seat back. Remove two (2) 10mm bolts from seat bracket. Lift section of seat back and pull to remove (Figure 2).
3. Remove one (1) 10mm bolt securing seat bracket. Lift seat section and pull to remove.
4. Pry out both pillar rimpanels starting at the top. Continue prying downward to release and remove.
5. Remove two (2) 14 mm bolts from seat belt guide on passenger's rear side panel. Remove guide (with belt) and lay aside (Figure 3).
6. Pry open screw cover behind grab handle and remove one (1) phillips screw from opening.
7. Remove one (1) push pin retaining clip from rear side panel located near wheel well.
8. Starting at the rear of passenger's rear side panel, pry out panel and work toward door opening to release and remove.
9. Pull to release three (3) plastic fold-down clips on front edge of rear deck panel (Figure 4).
10. From inside trunk, disconnect brake light wiring harness located under rear deck.
11. Starting on passenger's side, work hands under rear deck panel to release clips. Work across panel. When clips are loose, work panel toward passenger's side. NOTE: Lift driver's rear side panel to work deck panel from under side panel. Remove rear deck panel.
12. Remove four (4) 8mm screws securing speaker. Pull out speaker, disconnect and remove.
13. Connect speaker wiring adapter of replacement speaker to vehicle speaker connector. Secure new speaker with screws previously removed.
14. Test speaker operation and reassemble rear of vehicle by reversing disassembly steps.
Bellz is offline   Reply With Quote
Sponsored Links
Old 03-04-2008   #2 (permalink)
juice123
New Member
juice123 is an unknown quantity at this point
Re: DIY: Rear Speaker Install for Coupe
hello
Thanks 4 the info
Do you have link with the images you
Refer to on the Diy rear speaker install
Thanks
juice123 is offline   Reply With Quote
Old 03-04-2008   #3 (permalink)
sl33pyriceboi
Ultimate Member
sl33pyriceboi's Avatar
sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold
Send a message via AIM to sl33pyriceboi
you noob............ that was made 6 years ago.....look at teh date......he's probably not even on there...
search some more for it....its there. i know cuz i used it.
talk bout bringing a thread back from the dead........
__________________
7thGen.MT.C.
Quote:
Originally Posted by gearbox View Post
alot of people just talk to say something. most of the time they have no idea wtf is going on lol
Quote:
Originally Posted by manahoonie View Post
lol. well we got newbs to use the SEARCH button.... NOW the next step is to look at the date
Step 1) SEARCH
Step 2) DATE CHECK
sl33pyriceboi is offline   Reply With Quote
Tags
02 , 2001 , 2002 , 2003 , 2004 , civic , coupe , deck , honda , install , rear , removal , remove , speaker , speakers
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
