Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-05-2002   #1 (permalink)
DarkCivic
Platinum Member
DarkCivic's Avatar
DarkCivic is an unknown quantity at this point
Send a message via Yahoo to DarkCivic
Want to remove heavy sub box- advice?
So I have 2 JL Audio 10's in a box w/a 4oowatt Alpine amp and LOVE the bass that mother puts out, but it weighs so damn much and I want it out- is there a specific bass tube that I can hook up that will satisfy my bass-craving? OR is there a way to keep them without the box- maybe something custom? Thanks. To remove this ad, register today for free or log in if already registered!
DarkCivic is offline   Reply With Quote
Sponsored Links
Old 09-05-2002   #2 (permalink)
mohawkboom
Post Master General
mohawkboom's Avatar
Send a message via ICQ to mohawkboom
what that's only 50lbs of weight..your car won't notice it.. also you should have it mounted solidly..
mohawkboom is offline   Reply With Quote
Old 09-05-2002   #3 (permalink)
NAcoma
Member
NAcoma is an unknown quantity at this point
Send a message via AIM to NAcoma
have the mofos put into the floor..stealthy sub trunks
NAcoma is offline   Reply With Quote
Old 09-05-2002   #4 (permalink)
Ed
Ultimate Member
Ed's Avatar
Location: Deathie Elaine and Pecosa Land, Hudson, Ohio, US
Ed will become famous soon enough Ed will become famous soon enough
Send a message via AIM to Ed
A fiberglass enclosure would be lighter, you could build yourself one of those.
-Ed
Ed is offline   Reply With Quote
Old 09-06-2002   #5 (permalink)
WhiteRabbit
Ultimate Member
WhiteRabbit's Avatar
WhiteRabbit should not be questioned WhiteRabbit should not be questioned WhiteRabbit should not be questioned WhiteRabbit should not be questioned WhiteRabbit should not be questioned
Send a message via AIM to WhiteRabbit
fiberglass is heavier, unless you build directly (and i mean DIRECTLY onto the spare tire well) and can therefore use less glass to get no flexing.
is yoru problem acceleration? or handling?
if handling is your problem, try to locate the box as close as you can to the wheel wells. the more weight that sits on the wheels as opposed to basically on top of your liscence plate, the better off you will be handling wise.
if you are just looking to lighten your load, rebuild your box out of .75 inch furniture grade birch, its far lighter and also far stiffer than MDF, all at a nice price tag of $50ish for a 4'x8' sheet.
or you can try running your woofers freeair, only wood youd use would be the baffle, but you lose the ability to put thinks in both the trunk and the cabin at the same time (like a bike) and risk having your woofers sound bad, as I dont think anyone has tried successfully (or even tried for that matter) running those woofers freeair.
WhiteRabbit is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
Sound Deadening DIY
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
Its that time again...post your systems...
MTX Jackhammer! Don't they know when to draw the line?
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
