Another Speaker Question: 2003 Sedan
Rep Power: 0 Another Speaker Question: 2003 Sedan
Hi All,
Just a quick question, (and I apologize if these types of Q's are junking up the boards), but are the stock 6 1/2" speakers in a 4 door 2003 the same all the way around? I have a blown one in the front and bought an upgrade with some Socosche spacers. I think the spacers are like 1". Looking at the aftermarket speakers, (Sony XS 1641). I think I can use the spacer since the bottom depth is 2" flat. But I'm fearful the top mount is going to force me to cut the stock door panel. If that's the case, I'd rather throw these guys in the back, temporarily move the rear OEM's to the front,and then upgrade to something with less top mount.
Does this sound feasible or will the rears not work in the front?
Re: Another Speaker Question: 2003 Sedan
They are both 6.5. Crotchfield says so. So you can use them in the front but..... you will need to drill holes into the metal or rig something up with your old speakers because the fronts are held in place with clips built into the speaker.
https://www.civicforums.com/forums/21-i-c-e-electrical/289740-diy-front-door-speaker-install-coupe-sedan.html
This one shows how to do it by drilling into the door.
You could just get some .5" spacers to just clear the back and not worry about hitting the front of the speaker. Save yourself the hassle of doing twice the work.
RolandP
12-31-2015 05:49 PM
10-29-2015 01:12 AM
