Power Door Lock wiring
Rep Power: 0 Power Door Lock wiring
Hey guys I have a wiring question. I have a 2004 honda civic lx. I bought the car salvage to find out that components of the wiring harness were missing. I have sorted through most of the issues but have a stubborn one. I want to get my power locks to work. I have done some research and it appears that a negative pulse is sent to the multiplex control unit through the switch with the white/blue and white/green wires. This pulse in turn sends the proper lock or unlock signals to the respective actuators. When I looked up where the wires from the switch go it says there is a grey connector above the drivers side kick panel. I have no such connector. If anyone has a pinout for the wires that are plugged directly into the under dash fuse/relay box so I can determine where these wires go it would be greatly appreciated. Thank you.
Re: Power Door Lock wiring
momentary ground pulse from door panel switch should cause MICU to activate locks
white/green is for unlock, ends at terminal Y10 in the MICU/fusebox (directly into MICU)
white/blue is for lock, ends at terminal Y12 in the MICU/fusebox (directly into MICU)
Y is a light green connector with 13 terminal holes
20 pin harness connector (C751) where the door harness connects to the dash harness, that connector would be nonexistent on a DX plain-Jane model, that may be why you don't have a connector there?
You sure this car is an LX?
LOL Does it have power windows that work or did you have to wire those up too?
Is the fusebox gonna be right for an LX car?
Does it have a MICU that can run power locks?
Got a VIN? Does the VIN plate on the dash match the VIN tag in the door jamb?
Do the door VIN stickers all match the other VIN tags?
Rep Power: 0 Re: Power Door Lock wiring
The vin doesn't match the door jamb. It matches everywhere else. 1HGEM21154L025334 is the one on the dash. If its a dx is the lock pin in a different place? the lock actuators are on both doors. Thank you so much for helping
and yes I did have to wire up the windows myself. Fed the drivers side off the ignition and then connected the passenger side. Is there somewhere for a complete pinout of that underdash box?
The VIN you posted ---(the dash?) came out of a
2004 Civic
2 door coupe
DX Value Package
manual trans
black/black
49 state emissions
No wonder you have a ton of missing wiring. Damn salvage rebuilder hacks.
Has this car passed your DMV or secretary of state inspection with the wrong/mismatched VIN plates?
Maaaybe you should go there first... you may not want to invest any more into this until you know if this is legal 100%.
I know in my state those secretary of state guys go apesheeet over wrong or missing VIN plates. (Several years ago I caused someone some grief because I replaced a dashboard and forgot to move the VIN plate to the new dash.)
2004 Civic
2 door coupe
DX Value Package
manual trans
black/black
49 state emissions
A DX did not come with power windows or power locks
I had it registered in CT. They had a quick simple emissions test and you were out the door. Now I'm having the vin checked tmrw in RI. Hope it turns out well. I never noticed the vins being different I'm so silly. Is there anyway to wire this up? Both latches have lock actuators that work. I tested them with a hot wire and ground. I could put them on a polarity reversing switch. Idk if there's another way out.
pin locations on that fuse box
https://www.civicforums.com/forums/1...e-updated.html
SunaEpa
10-07-2015 12:02 PM
tropicola
09-25-2015 07:02 PM
