Maintenance Light Fix
Re: Maintenance Light Fix
You might put a set of spade terminals in the wiring to make any future removal simpler!
Great Idea Thanks
I wanted to keep it simple. The wires are long enough to pull out the cluster for a future bulb replacement. I have noticed that the push button is hitting the switch in the cluster on the side instead in the center. This could be a reason the switch to malfunction.
mattdoc
03-14-2017 12:10 PM
tylerginevan
04-27-2015 12:29 PM
