DIY: Alternator Replacement
Old 01-18-2015
  #31
mikey1's Avatar
Re: DIY: Alternator Replacement
okay now i see.....
it is very common for that top part to fit in VERY tight/snug, i think i had to hit mine with a block of wood and hammer to get it to go back in after my last timing belt job (hit the wood with the hammer, not the alt)
its normal (in my experience) for that to be a very tight fit, i recall cursing at it for quite some time, i would keep trying, i dont think its a problem with the alt or design,
how far is it off?
measure the distance across that span on the old alternator, and measure the span on the new alternator
Old 01-18-2015
  #32
Mag1c's Avatar
Mag1c is an unknown quantity at this point
Originally Posted by mikey1
okay now i see.....
how far is it off?
I planned on hitting it like you suggested but I'm wondering if they somehow sent me the wrong alt bc the OP's is the same one I have and his does not have the groove...
It was a tight fight getting the old alt off and was a bit of a pain but there is no way I will be able to get the new alt on without hammering the groove in quite a bit as it protrudes out too much and the old alt has no groove protruding at all.
I took a break for now but I will measure the distance next time I go to the garage.
Old 01-19-2015
  #33
Mag1c's Avatar
So I started up the car today and heard a squealing sound. Turned the car off immediately and noticed the power steering belt is loose but yesterday after putting it all back together it was tight as can be, the belt on the alternator seemed tight and fine. The power steering belt is loose as can be though...
One thing I did notice when putting the power steering pump belt back and the other belt was that the wing nuts didn't really seem to tension the belt as much as where I moved the alternator/power steering pump. Those tightened up the belt when being moved.
Any ideas what to do from here?
Old 01-19-2015
  #34
mikey1's Avatar
you have totally lost me.....
you should only tighten the alt bolts and power steering pump bolts FINGER TIGHT,
after that you tighten the wing nut(s) till the belt is properly tensioned,
THEN you tighten all the bolts,
did you do everything in this order?
Old 01-19-2015
  #35
Mag1c's Avatar
Sorry I think I'm being pretty paranoid.
I went back and tightened the power steering belt properly. Then, drove the car around the block (AFTER letting it idle about 10 minutes.)
Here is a video of the engine running:
https://*******/NlwL
I think I'm probably being paranoid but there is a slight wizzing sound by the belt area. Or does this sound normal to you?
Old 01-19-2015
  #36
mikey1's Avatar
the only "wizzing" sound i hear is your power steering pump,
and that sounds normal to me
Old 01-19-2015
  #37
Mag1c's Avatar
Alright. I figured I was being paranoid. This is the first "major"(to me anyways) car repair I've done.
Thanks for your help and to the OP for a great DIY. Even noobs like me can do it!
Old 01-25-2015
  #38
Kenny the Ricer
Kennykid2002's Avatar
Sorry for not seeing this earlier (Not very active on forums as much anymore)
Thank you mikey for stepping in and helping the guy.
I believe my replacement had a similar issue with the shim protruding.
I think I just hammered it in flush, which was like 1 or 2 small hits, I wasn't going all hulk smash on the thing.
That's why its important to inspect for any differences once you pull the old one out.
Glad everything worked out for ya.
Old 09-22-2015
  #39
roguebetty's Avatar
roguebetty is an unknown quantity at this point
Hey there, quick question. What year(s) civic is this valid for? Just want to check before I get started. Thanks darlin'
Old 09-22-2015
  #40
drhawkinz's Avatar
drhawkinz has a spectacular aura aboutdrhawkinz has a spectacular aura about
Should be for any 7th gen Civic; which are 2001-2005 Civics.
Old 09-22-2015
  #41
roguebetty's Avatar
Ah man! I have a 8th gen... Thank you
mrohitredd
18
05-14-2015 07:35 PM
bsmiley
04-27-2015 01:27 PM
smmahan
04-15-2015 08:17 PM
thesushiboy
04-12-2015 02:54 AM
OPGForce
02-07-2002 09:43 AM
Quick Reply: DIY: Alternator Replacement
