Front Right Speakers Not Working
Old 07-09-2012
C-Russ's Avatar
C-Russ is an unknown quantity at this point
Hey guys, I feel like this is a simple fix, but I just can't figure it out. I recently swapped out stereos in my civic and for some reason, I can't get the front right speaker and tweeter to work. I figured that maybe I didn't connect the wires well enough when I installed it, but I set it up to where I KNOW the wires are indeed connected. They seemed to be working before I installed the new stereo. Does anyone have any ideas what I could be doing wrong? I literally played with the wires for hours and had no luck.
Old 07-09-2012
Prelude Owner
GolNat's Avatar
Re: Front Right Speakers Not Working
Is it a good stereo? Did you remove the door panel to look at the speaker?
Old 07-10-2012
got2run5's Avatar
got2run5 will become famous soon enoughgot2run5 will become famous soon enough
Try swapping speakers--put the bad one where the good one is and the good one where the bad one is and see if the same door still doesn't work. If it doesn't, then you know it's the HU or more likely the wiring from the HU.
Old 07-10-2012
99civic360's Avatar
99civic360 is an unknown quantity at this point
Upgrade your speakers.
ORskier
05-03-2015 12:54 PM
supercivic01
South
11-30-2001 11:27 AM
PimpBot5000
11-26-2001 07:15 PM
ademarco6
11-16-2001 10:19 PM
ademarco6
11-12-2001 06:52 PM
Quick Reply: Front Right Speakers Not Working
