Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 4 Weeks Ago   #16 (permalink)
Staninator
Member
Staninator's Avatar
Staninator is an unknown quantity at this point
Re: Amp mounting suggestions and/or pics of your own install
Quote:
Originally Posted by taylorsherk View Post
That's all custom fabrication man, I don't think he's going for that. Props on the setup though!
Staninator is offline   Reply With Quote
Sponsored Links
Old 4 Weeks Ago   #17 (permalink)
indoxsmokez
New Member
indoxsmokez is an unknown quantity at this point
i thoguht about using 4 awg all around..but that means i have to buy more wires...i had an amp kit with the 8ga power wire about 10 ft laying around thats why im doing it...just to keep costs to a minimum..i had a budget for this cheap system and even then im already over it lol...k i think im good ont he wires atm...
another question tho, i know i shouldnt mount amps directly to metal right..but is it really necessary to mount to a piece of mdf board?
as of now, im just putting the amps down there under, above the carpet of course... what would u guys do? board or no board?
last question...probabyl a noob question..this one is tripping me out...during connecting your amp to its power sources...all the manuals, and all the places online say MAKE GROUND CONNECTION FIRST before remote and power...is this right??? hook your amp up to its ground first??? i want to be very sure.
indoxsmokez is offline   Reply With Quote
Old 4 Weeks Ago   #18 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
i hooked up my ground last and it didnt blow up lol. i dont think it matters. i mounted my amp on carpet and foam with velcro.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 4 Weeks Ago   #19 (permalink)
indoxsmokez
New Member
thats what i was thinking...shouldnt matter if it battery isnt hooked up right..anyway thnx a lot guys, uve all been helpful
Old 3 Weeks Ago   #20 (permalink)
vsTerminus
Member
vsTerminus's Avatar
vsTerminus should not be questioned vsTerminus should not be questioned vsTerminus should not be questioned vsTerminus should not be questioned vsTerminus should not be questioned vsTerminus should not be questioned vsTerminus should not be questioned vsTerminus should not be questioned vsTerminus should not be questioned vsTerminus should not be questioned vsTerminus should not be questioned
I always disconnect my battery's negative first, and reconnect it last.
Whatever order you do things in at that point doesn't really matter, but I've always done my grounds last and never had problems.
As for mounting to MDF board, it's useful. I usually just screw mine into the carpet, if they are resting on the floor.
If you are mouting in any other position (Say, sideways on the back of a seat) then a piece of MDF is a very good way to keep your amps stable and in some cases necessary to keep them in place.
vsTerminus is offline   Reply With Quote
Old 3 Weeks Ago   #21 (permalink)
Mavrick272
Member
Mavrick272's Avatar
Mavrick272 is an unknown quantity at this point
On my 6th Gen my Alpine MRP-300 fit damn near perfectly in the trunk wall on the passenger side. If you pull back the carpet they'res a random 2 inch wide steel strut coming down that you can bolt one half of the amp to and then the wheel well has a fin-like thing on it that you can bolt the other side of the amp to (screwing it in through the carpet blindly was a BEEEOTCH). Not sure if it's the same in 7th gens. I don't think this place could accomodate a bigger amp than mine, and mine's just a little guy....
I hope I helped and I wasn't just flapping my gums!!
ID:	77501   Click image for larger version
__________________
'98 Honda Civic
'74 Porsche 914 (for sale!)
Mavrick272 is offline   Reply With Quote
Old 5 Days Ago   #22 (permalink)
norizbot
New Member
norizbot is an unknown quantity at this point
Mounted it on top. Drilled holes and used some existing holes to hold the amp + spacers.
norizbot is offline   Reply With Quote
Tags
07 , 09 , 2007 , amp , amps , car , civic , honda , install , installation , installing , mount , mounting , photos , trunk
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
