Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 08-17-2009   #1 (permalink)
brokedown711
New Member
brokedown711 is an unknown quantity at this point
radio/hvac popping out + wiring Q's
Anyone have issues with the dash/HVAC not fitting correctly after a radio install? I'm only missing one clip but the top clip on the left side (right below the left vent, so the vertical clip, not the horizontal one) is still there but something is pushing it and making it pop out. Not sure what, it got dark but I messed around with it for a while even taking the radio out. I feel like it's the kit, but I'm not sure.
im gonna tear into it again tomorrow, gotta install the amp/sub anyways and one of my illumination bulbs is burnt out.
any ideas?
Also, I have the orange, orange/white and blue wires heatshrinked so they don't short out.
I think the solid orange (labeled illumination) on the Metra harness is what I need to hook up to my radio so it dims when the interior illumination is on. I'll check it with a meter, it should show 12v+ when the dash lights are on right?!
Does the antenna need the 12v+ from the turn-on/trigger wire from my radio? the pioneer only has one switched wire (blue/white) but luckily the antenna is in the window otherwise it would be extended anytime the HU was on.
Thanks in advance
Oh yea, Best Buy is such a ripoff: $21.99 for the dash kit, $21.99 for the harness I'll be getting another one ASAP and returning this crap, you have to be kidding me.
brokedown711 is offline   Reply With Quote
Sponsored Links
Old 08-17-2009   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: radio/hvac popping out + wiring Q's
you need to connect the power antenna wire otherwise you will have bad reception, even with a window antenna. the illum wire can be connected if you want the deck to dim when you use the dash lights. as for the piece not fitting, its usually cause the cables are in the way. make sure everything is tucked away and not getting stuck in the back.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 08-17-2009   #3 (permalink)
unTuned
Super Member
unTuned's Avatar
unTuned is a jewel in the rough unTuned is a jewel in the rough unTuned is a jewel in the rough
Send a message via MSN to unTuned
you dont really need to use the orange or orange/white wires. a lot of people run into nothing but problems with them. if you are that concerned with illumination and dimming, i guess you can. but 90% of people on here have nightmares with it and end up burning out lights everywhere. i would stay away. what is your new deck? a pioneer what?
i taped off and left my orange wires untouched on both sides and i have no problems at all.
as for fitment, like gb is saying, just make sure everythings tucked out of the way. if it ends up being the dash kit, you can buy a dash kit and harness online for cheaper than you can at the store. i had no problems either. you can also get the better metra dash kit for our cars that no store carries. they all carry the crappy one with the ugly pocket on it.
unTuned is offline   Reply With Quote
Old 08-17-2009   #4 (permalink)
04 Honda Civic
Super Member
04 Honda Civic will become famous soon enough 04 Honda Civic will become famous soon enough
Everything should fit just like it came out make sure everything lines up. On my double dinn avic I had a ton more wires then the factory radio. But since everything is neat it fits fine.
04 Honda Civic is offline   Reply With Quote
Tags
2001 , 2007 , civic , deck , honda , popping , radio , window
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
