Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > I.C.E. & Electrical
I.C.E. & Electrical Post all your I.C.E. (In Car Entertainment) and wiring questions here. (Audio, video etc.)
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-02-2009   #16 (permalink)
unTuned
Super Member
unTuned's Avatar
unTuned is a jewel in the rough unTuned is a jewel in the rough unTuned is a jewel in the rough
Send a message via MSN to unTuned
Re: Question... Alpine CDA-9805
ok if you look at the picture attached:
labelled A: this is the spot where you will plug in the factory antenna plug. its pretty simple. at least that looks like where youd plug it in. it should be just a single hole but its hard to tell from the picture. the thing i labelled with a question mark looks like just a screw hole but its hard to tell unless you get a better picture. maybe the antenna plug goes in there but i doubt it. i think it goes in where i labelled A
labelled B: these are where you would plug your cables into. as you can see there are 3 sets. two of them should be labelled out and are spots you would plug rca cables that would run to an amp, and the last set should be labelled in. you want to plug your ipod wires into the in set of holes.
labelled C: this is the spot where your alpine harness will connect. your alpine harness will plug in there with a bunch of wires sticking out. when you get your aftermarket harness from the store, plug that into your stock harness, then connect those aftermarket harness wires to your alpine harness wires. you can tape, solder, or crimp them. it doesnt really matter. crimping is usually the best because they stay solid but can be undone if you want to change your deck out one day. i also attached another picture to show how that setup should somewhat look like.
i dont think i seen you mention if you are installing a full system with an amp and sub. if you are theres a bit more you should know.
ID:	76815   Click image for larger version
unTuned is online now   Reply With Quote
Sponsored Links
Old 07-02-2009   #17 (permalink)
unTuned
Super Member
unTuned's Avatar
oh this is also very very important.
you will have orange wires coming out of both harnesses. some are solid orange, some are orange and white. dont connect any of them. they are usually called illumination and or dimmer wires. you dont need them. you will only risk burning out some of your dash lights by doing it. take all of those from both sides, tape the ends off and make sure none of them connect to each other.
also, take the black ground wire from the aftermarket harness and tape that off as well. then take the black ground from your alpine harness, put a little ring terminal on the end, and directly connect that to any piece good solid piece of metal somewhere inside there so your deck is grounded directly to the chassis and NOT grounded to the ground wire. if you connect the two you will run into problems later on like i did when you get a bad ground loop that ruins your sound quality big time.
Old 07-02-2009   #18 (permalink)
KurtyG123
New Member
KurtyG123 is an unknown quantity at this point
Send a message via AIM to KurtyG123
The labelled B part says (from the Top) F,R,SW.....where would i plug the ipod?
EDIT: nevermind...i had to buy a AUX input adapter that hooks into the cd changer outlet.
KurtyG123 is offline   Reply With Quote
Old 07-02-2009   #19 (permalink)
unTuned
Super Member
unTuned's Avatar
oh yea that sounds right. f=front r=rear sw=subwoofer. its been a while since i pulled the deck out.
so yea youd need to plug those rcas into something else and probably into the front of the deck like youre saying.
are you hooking a system up or just changing your head unit out? if youre running a system youd need to run rcas from the head unit to your amp.
Old 07-02-2009   #20 (permalink)
tbohar
Senior Member
tbohar's Avatar
tbohar is on a distinguished road
Does the deck have an aux. input? If it does not you can't hook an ipod up to it this way. You might want to double check that. I suggest you use the iPod interface that comes with the deck as it is much safer. All three of those plugs seem like outs to me.
tbohar is offline   Reply With Quote
Old 07-02-2009   #21 (permalink)
KurtyG123
New Member
im just switching out the head unit. the system is for another time...christmas...maybe birthday. haha
Old 07-03-2009   #22 (permalink)
EggRollBandit05
Super Member
EggRollBandit05's Avatar
EggRollBandit05 will become famous soon enough EggRollBandit05 will become famous soon enough
Send a message via AIM to EggRollBandit05
like i said get the wire which hooks up to the cd changer input if your headunit has that capability. its either gonna be a hit or miss with this wire ive tried a couple. first wire i tried connected cd changer port to ipod dock connector, problem encountered... i couldnt change the volume on either my ipod or the headunit. second wire i tried hooked up cd changer port to headphone jack, volume could be changed but music only played through the front speakers. just a heads up.
btw i have an alpine 9831 and ipod touch 2g so your results might vary
__________________
Auto Driver By Force Member #13
EggRollBandit05 is offline   Reply With Quote
Old 07-03-2009   #23 (permalink)
electric130
I.C.E. Mod
electric130's Avatar
electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned electric130 should not be questioned
Quote:
yep. that's what you want to do.
electric130 is offline   Reply With Quote
Old 07-04-2009   #24 (permalink)
KurtyG123
New Member
whats a good location to put the ipod? something discreet? not to much work either.
Old 07-04-2009   #25 (permalink)
unTuned
Super Member
unTuned's Avatar
theres another thread as of the past couple days of someone asking the same thing. there were a few suggestions in it...
Old 07-04-2009   #26 (permalink)
unTuned
Super Member
unTuned's Avatar
did you get the wiring portion of it with the harnesses all done? or are you pretty clear with the little picture i drew up?
Old 07-04-2009   #27 (permalink)
electric130
I.C.E. Mod
i have mine under the passenger seat since it's controlled through the head unit.
Old 07-04-2009   #28 (permalink)
brokedown711
New Member
brokedown711 is an unknown quantity at this point
the easiest place is the glovebox. this is also the best place, imo.
brokedown711 is offline   Reply With Quote
Old 07-05-2009   #29 (permalink)
KurtyG123
New Member
yeah man that really helped alot.
also i dont believe my ipod will be controlled through the head unit. and having it under a seat or in the glove box would be a pain. AND its only a 3 and a half foot cord
Tags
2007 , 9805 , alpine , aux , box , cda , cda9805 , civic , code , harness , input , ip , kind , languagejavascript , script , showmyipcom , srchttpshowmyipcomboxcreatescript , v10 , wire
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
DIY: Head unit install
DIY: Amp Wiring 2k1civic coupe
Sound Deadening DIY
~~~DIY Front Door Speaker Install Coupe and Sedan~~~
DIY: Installing Rear Speakers in a Sedan
Post pics of your trunk w/ subs, amps and whatever!
HID in TYC setup. With no projector conversion. Video on pg 17.
DIY: Custom Trunk II !with access to spare tire!
MTX Jackhammer! Don't they know when to draw the line?
Its that time again...post your systems...
Site Supporters
aluminum radiator
Honda car spoilers
